Question about Car Audio & Video
I have a Delco (Delphi # 21003872 I have no wiring harness want to put it in my 1998 Pontiac Grand Prix need help
SOURCE: i need an unlock code
goto the dealer ship fo the unlock codes that is the only way you will get them or if you bought the car used ask the previous owner for all thpaper work that came with the car new.there will be an unlock code somewhere in the paperwork.some vehicles come this way its called antitheft system that way if someone breaks in and takes the stereo it automatically locks up anthe only way to unlock it is to goto the dealership
Posted on Apr 20, 2008
StormStrikes
  • 104 Answers
SOURCE: I need a wiring diagram for my 2000 pontiac grand prix
I own a 2001 Pontiac Grand Prix GTP and may be able to help you out if you let me know what specifically you are looking for.
Posted on Jan 02, 2009
USfalcon
  • 175 Answers
SOURCE: codes for a 1995 pontiac grand prix stereo delco
the best way to do this is u can call any pontiac delar close to your place and they will give you the code direct by enter some information to your car radio
Posted on Mar 15, 2009
frcs68
  • 1605 Answers
SOURCE: i am trying to put
the red usually is the power input, black is the ground.
attach a ground wire to a 1.5v battery and tap the + of the battery to any of the stripper, when you hear the tap sound from the speaker,that will tell you what wire to which speaker.
if you have any wire left over, try for power ant.
Posted on Apr 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: 1993 Pontiac Grand Prix Wiring Diagram Needed
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach Purple/White Multi Coil Pack
Brake Switch White Brake Switch
Trunk Release Black Switch
Trunk Pin n/a
Parking Lights Brown Light Switch
Head Lamp Yellow Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Dark Blue (-) Driver's Kick some Models Blue/White (+)
Door Lock Light Blue Driver's Kick Panel
Door Unlock Black Positive Trigger
Horn Wire Black (-) Steering Column
Windows Up LF=Blue, RF=Blue/White
Windows Down LF=Dark Blue, RF=Tan
THanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
I need a wiring harness diagram for 2006 Pontiac Grand Prix base model stereo system
http://www.modifiedlife.com/2006-pontiac-grand-prix-factory-stereo-install-diagram/
May 25, 2015 | 2006 Pontiac Grand Prix
Where is thermostat for a 1997 pontiac grand am
Wow,you have 2 different vehicles listed Christy,and I will send both,k.Here's the Grand Prix one.
Aug 05, 2013 | 2004 Pontiac Grand Prix Thermostat by AC...
When i change the fuel pump do i have to change harness and sending unit?
you can buy the pump by itself.sometimes there may be a wire harness to replace but will come withwith the pump.always use a delco/delphi brand the others dont last
good luck
Jun 10, 2011 | 1994 Pontiac Grand Am
Oil capacity of 2002 grand prix
Right around 4 3/4 quarts. Use an AC Delco filter. There is a difference and this will prevent low oil pressure.
May 22, 2010 | 2002 Pontiac Grand Prix
1998 pontiac grand prix starter
disconnect the negative battery terminal first then disconnect the positive treminal so there are no accidents, raise the car safely go underneath & remove the starter cover should be 3 10mm bolts holding the cover on then remove the 2 through starter bolts 15mm then disconnect the + battery cvable from starter then disconnect the solenoid wire should be a 7 mm bolt. good luck
Sep 10, 2009 | 1998 Pontiac Grand Prix
My A/C is squeeking and I need to replace it. Can someone give me instructions on how to replace the A/C Fan Motor?
The Blower Fan is located under the glove compartment on the passenger side. You have to take out the three plugs holding the carpet on then you can see the blower motor. Take off the three screws holding on the blower motor, disconnect the wire harness then just do every thing in reverse to put the new one back in!!!
Good luck and hope this helps.
May 22, 2009 | 1998 Pontiac Grand Prix
Codes for a 1995 pontiac grand prix stereo delco
Mar 15, 2009 | 1995 Pontiac Grand Prix
Car Audio & Video Logo
579 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
