Question about Craftsman Garden
Press washer starts an runs for 5 min then shuts down/ restarts in a few min then shuts down again
    Problem Solver:
  • 13 Answers
The previous solutions are very important to confirm first. If your pump is in good serviced order then look to a valve adjustment.
Posted on Oct 20, 2012
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. The high-speed exhaust air must pass freely.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas, and then put in new gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Check small engine repair shop or auto parts store for gum out, and don't store engine with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way on the spark plug?
Posted on Oct 14, 2010
How do I fix my forced air heater?
Check for sensors on the unit that might be failing. I think many heaters have safety interlock switches on them now.
Overheating... Too Hot
Position Sensor... Knock it over & it turns off.
Loose wires....
Obviously turn it off when looking inside
Good Luck
Feb 21, 2015 | Heating & Cooling
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
Pressure washer problem
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, !!
Feb 18, 2012 | Garden
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
My 6030 has suddenly shut down!
it shutted down because (maybe)
of the folowing reasons:
1.) Error
2.) You have overloaded it,
3.) Full Memory.
try removing the battery (5 mins)
the put it back again.
then press on..
if it wont want to start.
charge your cellphone.
then try pressing the on button
Nov 02, 2007 | Nokia 6030 Cellular Phone
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Garden Logo
785 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
