Question about Banner Faucets Castille 600 Series Brushed Nickel Bathroom Faucet...
How can I keep the handle from getting loose on my banner lavatory faucet? I have to tighten the screw on the handle weekly.
  • 2,841 Answers
Install a lock washer on it. Get one that fits perfectly.
Posted on Oct 14, 2010
How to remove handles
I have extracted the legend of figure 5B of the installation instruction here for your reference:
Remove handle from the faucet by loosening set screw (1) and pulling off handle. Once handle is removed, loosen set screw (2) from the bottom of the handle, remove accent (3), replace with new accent, tighten set screw (2), replace handle on faucet and tighten set screw (1).
Here is the link for the installation instruction:
http://www.deltafaucet.com/media/MandI/40033RevC.pdf
Dec 21, 2013 | Delta 2565-217 Botanical Double-Handle...
How do I get the handle off so I can tighten it up to eliminate wobble
look for a small hole in the bottom of the faucet handle,, it holds a allen type or a slotted screw for retaining the handle,, ( more than likely on a moen or Kohler its going to be a allen head,) ,, remove that and your handle should come off
Sep 16, 2011 | KOHLER Forte Widespread Lavatory Faucet...
Handle is loose enough that it doesn't catch to turn the valve. Not really sure how to tighten this
There is normally a cap on top that needs to be popped of to gain access to the screw. Look closely to be sure before prying it off, it could have threads.
Apr 01, 2011 | Kohler K-12265-4-BN Fairfax Lavatory...
Handle loose. how do I tighten?
should be a very small set screw at rear base of handle
Mar 10, 2011 | Kohler Forte Two Handle Centerset Lavatory...
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
May 03, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do I take a loose handle off of an American Standard Hampton faucet?
The following link is the installation instructions for your faucet.
http://www.americanstandard-us.com/assets/documents/amstd/install/Install_555.pdf
Basically, what you need to do is gently pry the cap (with the hot/cold indicator) off the top of the handle. This will expose a screw-head, that you tighten to fix the looseness or loosen to remove the handle. If it's the other part of the handle that's loose (the bit that sticks out sideways rather than the whole handle). I've attached a diagram of how that is attached.
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_555.pdf
Sep 07, 2009 | American Standard Town Square Two Lever...
Mini wide spread vanity tap handles ( mostly left ) are loose.
if there is a cap on top, remove with a sharp object(razor knife) and tighten phillips head screw Just guessing but this is a common setup
Jan 14, 2009 | Moen T4945/9300 Castelby Two Handle Mini...
Banner Faucets Castille 600 Series Brushed Nickel Bathroom Faucet... Logo
116 people viewed this question
Top Banner Plumbing Experts
Mike
Tom Chichester
Andrew Bugbee
Are you a Banner Plumbing Expert? Answer questions, earn points and help others
