Question about Refrigerators
I have a dixie narco gmd-79 single door cooler, how do I adjust the door return spring
2 Suggested Answers
SOURCE: Kolpak walk-in hinge adjustment
loosen the hinges slightly on door and door frame. Shim the door even in the door frame so its not touching on any side. Tighten hinge hardware and see if that helps. If it doesn't you are probably due for some new door hardware.
Posted on Oct 29, 2009
The bill acc. blinks 3 times, bill & cion mechs have been changed, still blinks three times. won't take any money or vend.
Try it without the bill acceptor attached to get the machine working. You did not say what kind of acceptor but three flashes often mean a bad sensor in the unit. Another possibility is that it is disabled from the vendor. Check that all the columns have returned to home position if it is a bag vendor. If it is a pop machine then take off the metal cover over the vend motors and CAREFULLY push down on the microswitches to see if the motors run. Pop may fall out as you do this so watch for it. After running all the motors or homing out all the columns try you machine again. You will probably have to get the bill acceptor fixed though.
Dec 10, 2015 | vendors equipment Dixie 276/368/501 Can...
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Dacor
chk the spring and the door hinge. it is probably the hinge-spring that is broke, or slipped out of the hinge. lol.
Apr 27, 2014 | Dacor ECS130 Epicure Electric Single Oven
I need a shop manual/repair manual for a dixie narco dncb 368, where can i find one? I have bought an old machine and trying to get it working.
whats wrong with the dixie I spent ten years repairing these for coke and pepsi cola so if you have any questions I can help you with the repair I await your reply thanks again Rick
Apr 29, 2011 | Refrigerators
We have a Dixie Narco DNCB 240M/138-6 PE2299 Soda Vending Machine How do we increase the amount per soda?
Check behind the coin mechanism. When you open your machine, pull out the coin mechanism. You will see a set of dip switches there. Go to this page for more help. http://www.vendingadvantage.com/troubleshooting.htm
Apr 13, 2011 | Vacuums
My pepsi machine is not keeping the beverages cold, i was going to recharge it and put new freon in it. My question is, can i use a different rated freon than the one recommend with the...
Yes the new refrigerants can be used, however you must be EPA Certified. Also why would it need re-charging ? Leaks must be repaired.
Dec 05, 2010 | Refrigerators
Oven door seems sprung as if a spring may be shot and door dose not close all the way?
You need to replace both oven door hinges, as the springs are weak, and there is no adjustment available.
Sep 25, 2010 | Cadco OV-400 Electric Single Oven
How to install a triton 79
It should just stick on the CPU, but I suspect that the heatpipes are hitting the plastic shroud around the socket on the motherboard. If that is the case, I believe you can remove that plastic shroud so that the cooler can settle down the extra half a centimeter and make contact with the CPU.
Since the cooler doesn't use that shroud (I don't think) then this should be ok. Is this the problem you are having? If you could provide some pictures that would be lovely.
May 14, 2008 | Intel Motherboard
Jenn-Air Expressions Mod. W30400BC
no adjustments hinges are mounted inside door panel right?check to make sure theres no damage to inner door panel
Mar 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
