Question about Bang and Olufsen Beosound 2000 Shelf System
One of my speakers on beolab 6000 has no sound coming out of it, where can i get it repaired or replaced ?
4 Suggested Answers
SOURCE: Hum from B&o active speakers
Hi,  You may try to not connect the ground pin of the main cable of Arcam Solo. Using a 2 poles adaptor is the simple way. Try to find hum is still there. And using better RCA cables, like twisted pair, quad wires cable is better. Because, it is long-run (over 2 metre long), EMI and RFI are easy to enter the signal path.
Posted on Mar 27, 2009
vetteman3002
  • 2299 Answers
SOURCE: i have a set of
This sounds like a wiring problem. I would disconnect the wiring from the speakers and reconnect it. Clipping is usually cause by excessive amperage. That is usually from a positive strand of wire touching the negative.
Posted on Jan 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have four Beolab 6000
That would depend on the unspecified 'TV system' and its speaker requirements and controls. Most TV's don't support directly-attached speakers. Since these are self-amplified, half the battle is won.
Have you looked at any manuals?
Register and download the 6000 manual for free at retrevo.com
http://www.retrevo.com/support/Bang-%26-Olufsen-BeoLab-6000-Speakers-manual/id/23302ci863/t/2/
The Beloab 6000 speakers DO support connection to non-B-and-O products through the RCA Line In jacks but that presumes you have external volume control.
The unnamed subwoofer probably won't work with a TV. More details would be needed.
This speaker system would work with any 'standard' component-style system if you wanted to use them for the TV AND other sources.
Posted on May 06, 2011
How I can connect my mac to beolab 2000? is it possible?
Not going to be be possible but you sure do have some nice speakers!. On top of helping people with their computer problems I also write music. Would love to hear myself through these. Anyway The 2000 MUST be connected to the main system only. Its designed to only work with the main system via a MasterLink Cable. Its really simply an extension of your master system and cannot be used for anything else. Hope these helps.
Nov 30, 2014 | Computers & Internet
Tv and speakers buzzing noise
If the hum is a low note continuous hum, its at 'mains' frequency. The power cables to the unit (or inside it) are getting too close to the cables that carry sound signals to the center speaker. The mains power naturally hums and if mains wires are near to audio kit wires they pick up this sound and play it through their system/speakers. Check the wires to and from it make sure the connections are good and firm. Seperate these wires by at least one inch from any power cables, use tape to hold them down and away from each other.
Dec 15, 2013 | Bang and Olufsen Audio Players & Recorders
I have four Beolab 6000 speakers and a sub-woofer. How can I use these with a Sony or Panasonic TV system?
May 06, 2011 | Bang and Olufsen Audio Players & Recorders
All i get is a humming sound from my LifeCam VX-6000
First I would need to clarify if that is the outside sound directly from the device or if that is the sound being recorded through the mic? If its coming directly from the webcam on the outside, I would suggest first testing it on another system then replace it. If its from the recorded sound from the mic, try reseating the webcam usb cable, then try checking the other audio channels that you can access by double clicking on the speaker in the bottom right, make sure the other channels are muted.
Oct 29, 2009 | Microsoft LifeCam VX-6000 Webcam
BeoLab 8000 no sound
try moving the l/r switch, if sp still dead then its an internal sp fault.if it comes to life the fault lies in the cable or unit.
Sep 18, 2009 | Bang and Olufsen BeoSound 2 Companion MP3...
Connecting a sonos 90 to BO 8000 active speakers
Does your sonus system has pre-out? you can directly connect one single rca cable to each output into the speakers. make sure, each speakers is set to left and right each channel. these switches can be found above the rca input of the beolab 8000 next to the power link input. You have to understand that by using powerlink source cable is ideal only for other bang&olufsen equipments......however, there are other options, if u don't have a pre-amp output of your amplifier, you can also modify the speaker out of the amp, thru a conversion cable available from bang & olufsen, with an rca cable left and right channel, without interfering with the powerlink.
Apr 03, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
hi , i just saw ur mail although I do not have the solution to this but I am keen to know how you are using these speakers as I too have identical beolab 6000 and beolab 9000. I was thinking of connecting them to a preamp. What do u suggest ? Pls guide
Oct 01, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
115 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
