Question about Bunn NHB Coffee Maker
We have a Bunn model NHBX-B, s/n 143308CH that leaks out the bottom rear and trips the GFI receptacle. Any recourse? Thanks
  • 189 Answers
Your brewer is still under the warranty. If you will call 800-352-2866 with the model and code date, we will send you out a new machine.
Posted on Oct 20, 2010
  • studiodocs12 Jun 04, 2014
    I also have this problem with my Bunn s/n033608ch. Is there a way I can fix this?
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
Sep 03, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn nhbx leaks water
Jun 30, 2014 | Bunn NHBX
Bunn nhbx leaks out of the bottom
according to BUNN it is not repairable . they won't sell the parts needed
Jan 19, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
We unplugged our Bunn and left it unplugged overnight to do some painting. When we plugged it back in the light doesn't come on the warmer and the water does not heat.
The unit is not getting power. If the receptacle is protected by a GFI, then press the Reset button. Otherwise, check that the circuit breaker (or fuse) to that receptacle isn't tripped.
May 06, 2011 | Bunn GR10 Coffee Maker
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
May 12, 2010 | Bunn NHB Coffee Maker
I have a bunn coffee maker the NHBX is the # it is leaking water from the resevoir
If you will locate the date code on the bottom of the unit and then call Customer Service, the machine will be replaced at no cost or if over 3 years old, at a reduced price.
Mar 21, 2010 | Bunn NHB Coffee Maker
GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Apr 23, 2009 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Mar 31, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn NHB Coffee Maker Logo
1,005 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
