Question about Linksys Wireless-G Broadband Router
Xbox is it the linskey with the problem or the xbox and if the linskey how do i correct the MTU(Maximum Transmition Unit)on the linskey?
  • 1 more comment
  • xboxmike Jun 02, 2008
    yes i have tested the network settings and it fails on the MTU and i think it fails because the MTU is below 1364
  • xboxmike Jun 03, 2008
    thank you very much
  • nsindian
    nsindian May 11, 2010
    Have you tested the Network settings from you XBOX console? If so, where does it fail?
My router isent connenting to the internet and i have followd what the information bucklet says to do but its just not working and i am going mad that i carnt go wireless
help me plz .........
Posted on Sep 17, 2008
  • 137 Answers
Log into router by typing the ip address of router, usually 192.168.1.1 into an address bar (IE or My Computer). Enter in the router username and password, usually defaults to blank username with the password as "admin".
Then on the setup page you can make the MTU whatever you want.
Posted on Jun 02, 2008
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Hey i have a thomson TG782T and i am trying to connect an xbox 360 elite to xbox live through an ethernet cable and i am having the mtu error come up. i already have an xbox 360 slim connected which works...
Maximum transmission unit is 1500, but for the Xbox 360 it "must" be set within the range 1364 - 1492
Since there's no MTU settings for the TG782T. your only choice is to replace it with routers like Linksys, Belkin, Netgear.
Jan 05, 2011 | Microsoft Xbox 360 Console
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My x box says change mtu to auto or 1364 how do i do this
My MTU is at 1500 and I get the same message. I don't think it's up yet.
Jun 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Xbox live MTU failure
The reason why you're getting an MTU error is because the MTU has already reached the maximum # of packets that are being sent. To resolve it.
Access the GUI of your Linksys Router and go to the MTU settings. Set it to 1500. The lower, the better
Apr 26, 2009 | Linksys Wireless-G WRT54GS Router...
My xbox live is saying mtu failed
MTU stands for maximum transmission unit, which is, the maximum data that can be transmitted each time a network device sends out a signal.
I don't think you can change the MTU in the Xbox 360 dashboard.
You will probably have to go through a router to get around it.
the Maximum transmission unit is 1500, but for the Xbox 360 it must be set within the range 1364 – 1492.
So please access to the router setting on your PC & set it within the range 1364 – 1492 or call your ISP or router manufacturer to assist you doing so if you do not know how to access to your router settings.
I can give some steps to access router settings,
The way to access to your router settings differs from one router to another but basically it will always be through your PC most of them would be as follows:
1. Open an Internet explorer page on your PC.
2. On the address bar type 192.168.1.1 as for Netgear routers and 192.168.2.1 as for Belkin routers or 192.168.1.1 as linksys routers, if you have even any other brand you can try these three numbers I reckon one of them will work.
3. Then you click GO.
4. You'll get your router settings main page on the screen asking you for your Username & password usually by default the password will be even the same as the Username (Username: admin, Password: admin) OR it will be password (Password: password).
5. You can there look for MTU settings, it differs from one router to another you can just look for it then set it to 1365 as we said before.
Hope my info fix your problem,
Thanx for using fixya,
Cheers.
Sep 29, 2008 | Microsoft Xbox 360 Controller
Says i don't have enough MTU
MTU is Maximum Transmission Unit. Would this happen to be with Xbox Live?
Even if it isn't, this link should explain the situation a little better.
Jun 13, 2008 | Video Game Consoles & Games
Mtu
If you have your Xbox connected through a router, most routers, on their control panel (192.168.1.100 for example) give you the option of setting an MTU, or leaving it to default. This option is normally found on the setup page of your routers control panel.
MTU stands for maximum transmission unit, basically a speed thing.
If you can set it, change it to something above 1500 depending on how fast your internet connection is, but I am fairly certain that 1500 is the minimum that you would want to have set for xbox live.
Another way to do it is, if your router has this option, set the MTU to Automatic. That way your router (should) be able to do all of that dynamically as the need arises.
I hope this helps to solve your problem, good luck!
May 16, 2008 | Microsoft Xbox 360 Console
Xbox live
MTU maximum Transmit Unit, by default should be set to 1400, if you are going to make changes to the MTU it should be in increments of 8 IE if 1400 humdred is not working try 1392 then 1384, 1400 is the standard accepted unit size for successful DSL data upload.
May 17, 2007 | Conectl Cord Minder with Ethernet ThinCat...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
