Question about Viking 48" 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel (Electric and Gas) Kitchen Range
Considering buying Viking VDSC4856Q for only 2450.00. Does it require 220 hook-up? Should I buy it? What is your opinion?
    President:
  • 1,111 Answers
No, its 110V if you are thinking of buying the one you listed...its gas and a great range, its just out of my league with the price they ask for them.
Posted on Oct 15, 2010
What could be the problem with my microwave?
It's the circulation motor but I'd buy a new one They're just not worth fixing when considering cost and service life. The source of the humm and the source of the sound are probably 2 different areas. Good luck.
Sep 30, 2015 | Viking Microwave Ovens
One of the electric burners on our induction cooktop is misfiring and making noise. Who can fix these things? Is it better to buy a new one?
I recommend to buy a new one, induction cooktop prices have come down a lot and there are good ones available for about $1000. FOr me, the only problem with putting a new one in was the hole in the countertop was too small for the new cooktop (Viking has a smaller hole requirement than most other cooktops). So be sure to measure the hole in the countertop before you buy a new one so you can buy one that fits.
Mar 16, 2015 | Viking Cooktops
Don't have money to buy new dryer timer ($85-$95). Can I just put a 220v timer between panel and 220 outlet?..
there is an issue with the amperage load on the timer..most dryers require a 40 to 50 amp connection to work properly.. using a timer thats not as heavy rated will catch fire from overheating!!!!!dont want to burn the house down...
Jan 23, 2013 | Dryers
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
I am considering buying a used unit but need to know the amps requirement
Most dryers require a 220VAC 30 AMP circuit. Some of the exotic ones use up to 50 amps but not many domestic ones.
Jun 08, 2011 | Dryers
AM CONSIDERING BUYING AN 05 JEEP CHEREKEE EXTREME SPORT. I HAVE HEARD LOTS OF PORS AND CONS AND WOULD LIE AN HONEST OPINION
an honest opinion would be: you paying for a badge that seems to still be living in the 40's. chrysler has alot of electrical issues. if you are looking for an suv with low maintenance issues, consider a toyota or nissan. if you are looking for more luxury, an m class mercedes (my personal favorite) or land rover.
Nov 04, 2009 | 2001 Jeep.5 Cherokee 2WD
I need to buy a new speed controller for my overlock sewing machine. Husqvarna Viking Husky Lock 905 any help pls. i need to know how much will it cost me and if it is possible to ship to Malta, Europe.
Should not be a problem to ship internationally. Contact an authorized Husqvarna Viking dealer. They should be able to order one for you and give you a price before ordering. Also be sure to tell them the power requirements in case it is different from the USA/Canada. Check Husqvarna Viking website for dealer closest too you.
Sep 13, 2009 | Husqvarna Viking 1
Product Reliability
in my opinion the oven is too big i have the eeb6500.5 and i swear buy it, i have seen many a 9600 come back from a customer either faulty, unrepairable or just not wanted if you want my opinion dont buy a eeb9600 or a eeb9800
Jun 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Machine stopped running, its getting power but wont run.
I would take it back to your service tech or choose another. It may be something simple that needs replacement, like a new cord. (or . . .)
Also, before thinking of buying a new machine, I would get another opinion.
Feb 17, 2009 | Husqvarna Viking 1
Open Questions:
Viking 48" 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel (Electric and Gas) Kitchen Range Logo
149 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
