Question about Altronix 6062 Access Control & Mag Lock Timer Module
How to wire a gate alarm using altronix 6062 - Altronix 6062 Access Control & Mag Lock Timer Module
What is wring.?
The programming on your remote buttons probably got overridden. Just reprogram your remote's buttons for the alarm and gate .
Mar 29, 2015 | Building Materials
Why does the alarm on my 2000 jeep grand cherokee not go off when the lift gate is opened
Hi Gloria, I'm glad to help!
Gloria, the most likely cause for no alarm when the liftgate is opened is usually because the controller does not see the liftgate open. 2 things can cause this. (1) The alarm switch on the liftgate could be bad. (2) The wiring going to the switch could be broken somewhere in the wiring. On the Jeeps its usually broken where the wiring is bending all the time between the liftgate and the body of the vehicle. If you pull the rubber insulator out you can then check the wiring. If the wiring is good then the next step would be to try an alarm switch for the liftgate. Hope this helps and have an awesome day Gloria.
Sep 06, 2014 | Jeep Grand Cherokee Cars & Trucks
Manuals for altronix
Here.
That's the instruction manual. Gotten from here:Website.
Jul 16, 2013 | Home Security
How do I fix the liftgate sensor on a 2005 nissan quest
I purchased a 2005 Quest that had same damage on the rear lift gate. If I crossed my eyes and pressed down on the magic spot 3% of the time I could get the door to close in a way the sensor would recognize so I didn't have the door open light turn on.
Too fix this problem I removed the interior panel from the lift gate which allows access to the the lock and some of the wires. almost directly behind the licence plate you have access to the inside the lift gate you should see 2 wires that appear to be going down the latch. I'm assuming one of these controls the power locks and the other is for the feedback sensor that tells the car the door is open.
on the drivers side of the opening that exposes the wires going down to the lock you will see there is a white connection for 1 of the 2 wires that is mounted to the inside of the lift-gate. All I did was squeeze and separate this connection and the car no longer recognizes the door is open.
I don't have an alarm so I don't know if this would mess up the alarm other than if someone broke in through the lift gate it wouldn't trigger the sensor.
I hope this helps
Jan 05, 2013 | 2005 Nissan Quest
2004 chryaler Pacifica tail gate location
I have run into this problem and i found that the switch that operates alarm and inside light is bad, the switch is located on the latch, the latch may need to be removed to replace the switch. some dealers do not sell just the switch, i have run into this problem where switch is not replaceable the complete latch needs to be replaced.
Another problem i have run into is the wiring going into the hatch breaks, the wiring from bendine due to door opening and closing breaks a wire or two due to bending , locate wiring coming into rear hatch and check each wire,
Sep 03, 2012 | 2004 Chrysler Pacifica
Location of tail gate alarm on 2004 Chrysler Pacifica
you may have a bad switch which is located on the latch asm
6062 multi purpose timer opens but won't close
Reset timer, and then check that programs do not have conflicting times or days.
Copy following link for manual:
http://www.altronix.com/p_pdf//6062.pdf
Contact Altronix for lifetime warranty if product is defect
Jun 12, 2012 | Hardware & Accessories
Altronix webcam driver
try here, just put in your model # and download the driver
http://www.altronix.com/index.php?pid=2
Aug 24, 2011 | Computers & Internet
Wher to buy eurotech EWC177W parts (drain pump)?
Poor Earth Grounding
One of the biggest problems with electric gates is poor installation. In particular, many people do not properly ground the gate or fence during installation. Grounding rods must be placed under the gate in order to keep it safe for people and animals. Drier climates require more grounding rods. An improperly ground gate can cost thousands of dollars to repair.
Barbed Wire Fencing
Some farmers have tried to electrify a barbed wire fence, but this is a major safety hazard to animals. Animals can get stuck in barbs whether or not they are electrified, but the added electricity can lead to their death. Barbed wire should be avoided on farms and should never be electrified.
Interference
Occasionally, electric gates may experience technical difficulties due to interference. Local radio, television, or telephone signals or wires can cause the interference for both the media system and the gating system. Such interference can cause the gate to lose its electric charge temporarily. The interference can also cause brief spikes in electricity in the gate, which can be a safety hazard to people or animals.
Insufficient Animal Training
Since electric gates on farms are intended to keep animals in their assigned area, the animals must learn about the consequences of crossing the electric gate. Farmers or property owners must therefore train their animals to avoid the gates. To train the animals, owners must actually expose them to the electric shock. Owners who fail to shock-train their animals may find that their animals become obstinate or may get seriously injured.
Crime Target
Owners who install electric gates at the edge of their property often do so for security. Ironically, the presence of such high-tech gates may signal to would-be robbers that the owners are very rich, making the owners theft targets. Property owners may want to install an alarm system to accompany the electric gate to increase security.
Feb 23, 2011 | EuroTech EDV158 Electric Dryer
We are unable to program the timer past the date and time function. There is no cursor flashing, only the colon flashes between the time is entered
You posted under PT724A timer
Contact support at Altronics:
http://www.altronix.com/index.php?pid=9
http://www.altronix.com/index.php?pid=2&model_num=PT724A
http://www.altronix.com/p_pdf/PT724Aseries.pdf
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 16, 2011 | RTO PT724A 365 Day 24 Hr. Timer/Controller
Altronix 6062 Access Control & Mag Lock Timer Module Logo
88 people viewed this question
Top Altronix Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Altronix Hardware and Accessory Expert? Answer questions, earn points and help others
