Question about GE Kitchen Ranges
My mom has an XL44 electic ignition and we smell gas all the time. The maintenance guy says its normal. He says he smells gas from his too. This shouldn't be normal, right?
  • 1,557 Answers
Call your gas company and ask them if you should be smelling gas and watch then come running. we dont work with gas appliances but i do know the law in australia regarding this the best people to deal with are the supplier they take gas leaks very serious so try them
good luck
Posted on Oct 14, 2010
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
Intermitent gas smell
yes it is possible. a faint smell now and again from a gas stove is normal, as it has many burners to and oven. if smell is not constant, nothing to worry about.
Sep 09, 2009 | Kitchen Ranges
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
Oven won't work
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Aug 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 gas igniter replaced,lights up but doesnt ignite gas??
Take an ampreage reading on one wire of the new igniter. It should pull at least 3.2 amps to open the valve completely. Make sure the igniter is in the path of the gas too.
Mar 13, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Smelling gas at when stove is in prelight then going away
Welcome tkrogers,
You said,smelling gas at when stove is in Pre-light then going away.
In some stoves this is normal as long as it is a slight smell and it goes away when the stove or oven ignites.
You know gas really has no smell, but this smell is added for our safety!!
What is the Make,year ,and Model number of your range?
The gas must start somewhere until the flame ignites it.
So we smell a slight smell of gas until it burns.
Thanks,
Huuum
Please remember to lave a solved rating before you leave.
Oct 11, 2008 | Frigidaire Kitchen Ranges
GE XL44 Working fine but awful burnt propane smell
Remove the burners and clean them with EASY OFF oven cleaner. The passages are likely plugged and this causes incomplete burning of the gas. If you do smell raw gas shut the gas to the stove off RIGHT AWAY and call the local gas supplier.
May 12, 2017 | Kitchen Ranges
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Kitchen Ranges Logo
222 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
