Question about Craig Televison & Video
Newly purchased Craig CLC 503 says in the instructions that you can connect basic cable via the coax from the wall into the UHF/VHF port on the bottom of the TV. I can find no such port. Nothing else is labeled VHF/UHF and only the RF port will accept coax? How can I connect it to my cable service without having to obtain a converter box? The Craig instructions say that a converter box should not be necessary. Even if I had an extra cable box to what port on the Craig would it connect?
5 Suggested Answers
  • 398 Answers
SOURCE: reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Posted on Sep 01, 2007
  • 9 Answers
SOURCE: No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Posted on Jan 28, 2008
  • 1779 Answers
SOURCE: Digital Converter Box
# 1. Why are you using a digital to anaolg box when you only have a analog signal coming in? The box is designed to see digital information then converting it back to analog. Please explain further what you are attemping to do?
Posted on Mar 28, 2008
SOURCE: I'va a Mod CLC 503
In the menu settings, there are two things you need to change. There is a reception type that you need to change from "AIR" to "CABLE." You also need to set the channel to whatever your cable box is set for (mine is 4).
Posted on Dec 25, 2010
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
I have a sony EX4|40 with built in Freeview. However, the port on the tv is a UHF (?) port (Im not technically minded, my port names may be wrong so I hope you know what I mean), The cable which runs from...
It sounds like you connected the coax cable to your TV. What channel is the TV set on when you have the Freeview connected? Because you are using a coax cable, the TV should be set to either channel 3 or 4 (normally channel 3). Check to make sure your TV is on one of those channels. Also verify your receiver is on. Your TV has the several other type ports (HDMI, component, composite) as alternatives to pick up your picture. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 19, 2011 | DISH Network IR Remote Control
I'va a Mod CLC 503 (new out of box) Not able to receive (signal) when turned on. Attaching to "cable", no box or converter needed. The coax cable I'm using is good, out put from splitter is good....
Nov 10, 2010 | Televison & Video
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
Connection problem
You can connect via a coax cable from the sat. box to VHF input of your TV and tune on ch 3 or 4 or connect via a RGB cable to component input of your TV or a regular Audio/Video composite cable will connect sat. receiver to your TV use yellow color for video and red&white for stereo Audio then choos the connected input on the menue and watch sat.
May 27, 2009 | Hitachi 43UWX10B 43" Rear Projection...
No cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
176 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
