Question about Evolis Pebble Color Card Printer
I have an Evolis Pebble 4 printer. I am trying to print out cards from the Pebble 4, but the machine is not pulling the cards from the card holding tray. Because the cards are not being pulled from the tray, there are no cards w/logos being printed. Can this problem be fixed?
    New Friend:
  • 54 Answers
Just check for thickness adjustment pointer near card feeder . It should be 0.8 for standard cards.
Check in driver settings also if you have selected for manual feeding.
You may need to clean the Roller situated at feeder.
Posted on Apr 13, 2011
I have an Evolis Pebble 4. For each card printed, a white thin streak appears. This streak cuts through the entire card.
Try cleaning your printer first using the Evolis A5011 Cleaning Kit. If the line is solid and goes across the length of the card, you might have a burned/damaged pixel. Check with Evolis or your Evolis Card Printer supplier for warranty information, your printhead might still be under warranty.
-- The Pros at www.DiscountIDStore.com
Aug 28, 2011 | Evolis Pebble Color Card Printer
I'm using Evolis Pebble 4 to print card, i wish to let the printer flip the card itself and print at the back of the card. So i first set the duplex of the printer to vbPRDPVertical on VB6, and then i...
Dear Sir,
Evolis pebble4 printer is a single side card printer . It doesn't has mechanism to flip the card.
If you want to flip the card automatically you must go for Evolis Dualys or higher model.
Apr 04, 2011 | Evolis PEBBLE 4 Led Card Printer
I have a printer pvc evolis pebble, but it does not want to print
Check the connections of the printer and check if it prints the self test ( machine page )
Download the manual for better understanding of the printer
Download Manual
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 11, 2011 | Evolis Pebble Color Card Printer
Evolis Pebble 4 with a gold monochrome ribbon. Printing on pre printed blank cards. The print is not complete, almost as if there is not enough pressure on the card as it is printed. All the letters are...
Make sure you have selected gold ribbon in printer graphic properties.
Also you can try changing luminosity and treatment options in graphics under Advanced setting.
Check for print on a white card also as problem may be due to card surface also .
You should cklean print head also at once.
Oct 04, 2010 | Evolis PEBBLE 4 Led Card Printer
My Evolis Pebble 3 ink ribbon breaks after I print 2 cards.
First clean Rollers and print head . Check if you have increased luminosity and contrast too much in printer Graphic properties. If this doesn't solves your problem increase x offset little bit using Px;+ command in Dialog with printer
Aug 04, 2010 | Evolis Pebble Color Card Printer
My ink ribbon breaks after it prints 2 cards. I have an Evolis Pebble 3.
Clean all transport rollers . check for X offset by giving Rx command in Properties/Tools/dialoge with printers. Increase offset little bit using Px command
My Evolis Pebble 3 says feeder error but there is not. It won't pick up a card when you try to print but when you press the push button it feeds out a card without printing. It will alos not print a test...
You must take following approach
1. There is a lever at feeder for thickness adjustment . Check it for proper thickness.
2. There is a hanging lever which acts as a card presence detector just where you place cards check if it is stuck and try to clean sensors aside it by blowing air .
3.Check if feeder motor is working by giving Mf;+ command
4.Check for proper ribbon setting.
5. Try downloading firmware which is available as an exe file for different models on Evolis site.
6. diagnostic software is also available on site.
7. You can also do self adjustment to adjust sensors.
Aug 16, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis Pebble Color Card Printer Logo
671 people viewed this question
Top Evolis Office Equipment & Supplies Experts
Safe-Card ID...
Fred Block
Fred Block
k24674
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
