Question about Frigidaire Dishwashers
Dishwasher showing Er . Reads as follows: Drying Sensing Er Sanitized Low Clean * Serial # th44076578 model # PLD346ORDCO Professional series Have filled with JetDry but cannot delete Er message. Please advise. Brenda Brammar
  • Brenda Brammar Oct 14, 2010
    Teran:
    No just ER.
    Brenda
  • Frigidaire Master
  • 12,061 Answers
ER code, that indicates a keypad switch failure.
Below is a DIY self help Dishwasher repair help website.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
If you confirm the error code and it is an ER UO code then the vent fan assembly will need to be replaced.
If you can't verify the error code then I recommend a technician check this problem.
Posted on Oct 15, 2010
  • 10,515 Answers
Kindly provide few more details :-
1. Do you see any other error message?
2. Do you see Er Er or just ' Er '?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 14, 2010
Frigidaire dishwasher reads Er clean
http://www.appliancerepairlesson.com/2012/12/15/frigidaire-dishwasher-error-code-er-keypad-code
It could be thinking you are pressing a button for too long.
Try the above link answer for reset.
Or unfortunately it can be a shorted keypad.
Dec 01, 2015 | Frigidaire Dishwashers
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Jan 20, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
I have this code error on my dishwasher frigidaire gallery Sensing Sanitazed......Er......Low Clean.......................*
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
Jul 24, 2008 | Frigidaire Dishwashers
Frigidaire PLD3465REC dishwasher error??
Hi, I am having the same problem you describe above with the model nr PLD3460RDC1. Were you able to find out what it was? Thanks so much!
Jul 02, 2006 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwashers Logo
462 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
