Question about Mitsubishi WD-62525 62" Rear Projection HDTV
How do i play a sony dvd player through the hdmi plug? i have a cable and is plugged in. don't know how to play. help
    Problem Solver:
  • 14 Answers
If you have an input that does not work with anything else than its the hdmi input
Posted on Oct 14, 2010
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
I have a mitsubishi HD1080 series TV and wanted to know how do I plug in a dvd player. Then how do I get it to play.
Connect an HDMI cable from the DVD's HDMI port to an unused HDMI port on the TV. Select the input from the settings menu and name it DVD or select the DVD name. Turn the DVD player ON. Using the input select button on the remote, select the HDMI DVD input. Wait a few seconds while the TV and DVD player establish a connection. The DVD player menu should appear. Insert a DVD and enjoy a movie. Hope this helps. Regards.
Jan 02, 2016 | Mitsubishi Televison & Video
How to hook up DVD player to 19' led HDTV
The modern way is to buy a HDMI Cable
Plug it in to the HDMI Port on back of DVD Player
Plug the other end into spare HDMI Port on LED TV.
Put in a DVD & hit Play
Use remote control to select HDMI port on LED TV
If it does not have a HDMI port then you need a converter box which picks up the Red & White (sound) & Yellow (viideo) and converts to HDMI standard.
Aug 13, 2014 | Televison & Video
My tv displays "format not supported"
Too many variables with what you are describing here. How old is the TV and how old is the DVD player. Did you verify that the components were all plugged in to their corresponding colors....blue to blue, red to red, green to green. Is the RGB cable verified good. Another common mistake is to plug the video jacks into ex. VID 1 while the Audio is on VID 2. Make sure they are on the same numbered input and that the TV is on the input your jacks are in. The HDMI may not work because there are three different HDMI types and not all play well with each other. The problem can be fixed with an HDMI converter but gets into more cost. Eliminate above mentioned and repost. I would be glad to troubleshoot you through this.
Mar 12, 2014 | Sony DVP-SR500H DVD Player
I have purchased the blu ray dvd player do i need to by a coaxial jack as well as the hdmi jack
No,a HDMI cable alone will do the job.Just plug the HDMI cable one side connected to the HDMI port hub belong to the tv HDMI hub,the other side of the HDMI cable connected to the HDMI port hub belong to the Blu ray dvd player HDMI port hub.That should play ur Blu ray dvd player.U still have questions,read ur owner manual.
Jun 24, 2010 | Televison & Video
I just purchased a Sony DVD player...DVP-SR200P. Plugged it in and have no color...movies play in black and white only.
Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 10, 2009 | Sony DVP-NS700P DVD Player
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Region Code / DVD Player
DVD-player Sony DVP-NS715P r1/r3/r2-Japan don,t have solderless upgrade
(Example: PDA, DESKTOP, IRC, CD-R and etc....) in
variant MULTIREGION, and NTSC and PAL-enable, and Macrovision OFF.
The modification of this player is done only through special
Sony-Data-service-cable and special firm software through plugs
On main-board (plug CN-103) and on IR-board (plug CN-405).
Mar 19, 2008 | Televison & Video
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
