Question about Craftsman Air Tools & Compressors
How does the crank shaft and counterweight come off of the motor shaft, in the Sears 919.166600 compressor? Thanks Willy
3 Suggested Answers
Skinnerd1
  • 13 Answers
SOURCE: Sears compressor Model 919.155730 flywheel/motor shaft not secure
It could be that you are missing a shaft key, look to see if there is a groove in the shaft and in the flywheel if so there should be a key in this groove to keep the shaft from slipping.
Your local hardware store should have one. You will need to Measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
If it is a Woodruff or Half Moon key 2ea7913.jpg it might be harder to find the right one but a good hardware can do it.
Hope this helps.
Posted on May 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: where can I find an owners manual for my old sears
CLICK HERE for a PDF version of the manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 09, 2010
How do i remove the oil pan to get to the oil pump on a 1992 chevy s10 pickup 4x4
pick your battles cause your really going to have a ruff time of it. chassis in the way for the most part. you choose best way for you to do it.
May 24, 2014 | 1992 Chevrolet S-10
Campbell Hausfeld VS5006 Compressor runs slowly
Rmove the drive belt and check the motor. It should turn very freely by hand and if turned on should start up easily. If it turns hard check the armature bearings if it starts slowly but turns OK after you give it a push, you have a bad start capacitor. If the motor is OK check the pump. It should turn fairly freely except on the compression stroke where you should feel slightly more pressure is needed to turn it. If you can't turn the flywheel or it turns very hard, you should check the connecting rod to crank shaft joint and crank shaft bearings. These usually go bad if there is low or no oil in the crank case.
Apr 08, 2012 | Air Tools & Compressors
What is a counter balance on a chevy malibu inside the tranfer case
An internal combustion engine has a crankshaft, a clutch, and a transmission including a main shaft rotatable by the crankshaft through the clutch and a countershaft rotatable by the main shaft through gears. A counterbalance mechanism includes at least a primary counterweight rotatable in synchronism with the crankshaft, and a hollow shaft rotatably supported concentrically on the main shaft, the primary counterweight being integrally mounted on the hollow shaft, the clutch being corotatably mounted on the hollow shaft and operatively coupled to the crankshaft at the same speed as and in the opposite direction to the crankshaft.
Dec 31, 2010 | 1999 Chevrolet Malibu
Hitachi EC 12 2hp Air Compressor. Just get a buzz sound when plugged directly into 120v wall outlet. Piston and shaft turn freely. Have installed a new pressure switch. Just turned the compressor on...
Hitachi EC12 Air Compressor Parts : MASTERTOOLREPAIR.COM
Here is a site that says:
1. Are the capacitors good? (They get the motor going).
2. If they are, replace the stator, ($245)
If you don't find a good solution there, I would try taking it to a local motor rebuilder.
Gary
Dec 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Broken cog on compressor motor 919.166440
Below is a link where they have a variety of parts for smaller craftsman compressors.
I didn't see an exact match for your model however I think if you contact them they will probably be able to help you out. I'm sure that motor/pump model was used on several different models.
Hope it helps.
http://www.mastertoolrepair.com/craftsman-sears-parts-portable-compressors-c-271_535_537.html
Nov 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Remove the bearing on a 5hp 110 volt 28 gallon oil less compressor
This is very hard to do but not impossible. The problem is the rod journal is pressed on the motor shaft. You have to remove the coils / rear end of the motor and carefully place the rotor in a vise. Use a steel rod and hammer to gently force the crank off the shaft by hitting crank from rotor side thru vent holes of front motor housing. It will not be easy and you could easily damage shaft, crank or rotor. (but what the heck, it does not work anyway) If your are successful and able to replace bearing, press the crank back on using loctite then drill 1/8" hole thru crank into shaft and drive in a roll pin. Good Luck!
Oct 05, 2009 | Campbell Hausfeld Air Tools & Compressors
Sears 5 h.p. air compressor model 919176850 convert to 110 volt
pull the cover where the wiring goes into the motor, usually there is a wiring diagram on the underside. If not, go to sears online to see if you can get the manual for it
Jun 09, 2009 | Air Tools & Compressors
Hope this helps.
May 22, 2009 | Craftsman Air Tools & Compressors
Craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
May 21, 2009 | Craftsman Air Tools & Compressors
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
42 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
