Question about Gemini Sound Products P07 2-Channel Amplifier
Gemini GA 2000 both 4 internal fuses keep blowing off.2 8amp and 2 12amp.Please what course this problem.
    Sergeant:
    Champion:
  • 387 Answers
The power unit that feed the Amp is short this is why the fuse burn
its an hardware issue
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Posted on Oct 21, 2010
Gemini gvx15p powered subwoofer keeps blowing fuses
Fuses blow when there's an overload. Mostly caused by a semi-conductor device such as a transistor or IC that has become short-circuited. Transistors are easy to spot as when an Ohm-meter is placed on the terminals the ohm-meter will behave like you have touched the test probes together!
Jun 03, 2013 | Audio Players & Recorders
New subwoofer blows fuses
you have some wires touching causing it to ground.check wiring
Dec 27, 2012 | Gemini Sound Products Gemini GVX SUB15P...
1987 Chevy silverado gauge / idle fuse keeps blowing
The 20amp ga/idle fuse powers a hot fuel module which powers the oil pressure switch, the fuel pump relay, and the fuel gauge in the tank.
Any of the four components including the fuel pump can blow the fuse.
Jul 23, 2012 | Chevrolet Cars & Trucks
2000 Buick lesabre a/c keeps blowing fuses
If A/C fuse blows open you have a short to ground, youll need to inspect the wires if wire and connection are good then your problenm is the clutch of your A/C shorting internally, youll also need to know if the
A/C compressor is failing internally
May 14, 2011 | 2000 Buick LeSabre
The fuse from the AC keeps blowing up< what can be the cause?
i had this problem....it was the little ac fan in front of the radiator. must have picked up a rock and offset the fan blades so the shaft wouldn't turn and of course blow the fuse everytime i turned it on.
Aug 11, 2009 | 2000 Chevrolet Tracker
Fuse keeps blowing
If fuse keeps blowing that means that there is a shortage on AC wiring or switch controlling the air conditioner.
Also an abnormal power draw from AC caused by an internal fault on AC can cause the fuse to blow.
Test wiring and switch with a voltmeter, the most common is that there is a short to ground between wiring and car body somewere.
Apr 29, 2009 | 2000 Chevrolet Malibu
1999 golf, alarm rings when open with key fob cant turn off
the alarm itself could have an internal earth problem.... pull out fuse from alarm or disconnect alarm and see if fuse still blows
Mar 21, 2009 | 2000 Volkswagen Golf
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
Gemini Sound Products P07 2-Channel Amplifier Logo
179 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
sean tan
Level 1 Expert
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
