I plug it up and it will not work - Computers & Internet
    Genius:
  • 1,016 Answers
What are you plugging up, and can I have the serial numbers and name of the motherboard you are plugging up.
Thanks
Jason
Posted on Oct 14, 2010
    Brigadier General:
  • 10,406 Answers
Did it ever work?
If this is a NEW motherboard, it is still under WARRANTY.
Exercise the warranty to repair/replace it with one that does work.
Cylinder 2 not working Daewoo cielo 1.5i 1995
Do you have spark at cylinder 2? If not, check spark plug wire or spark plug. Another possibility is the ignition coil pack (the thing your spark plug wires run in to). Hopefully that is not the issue because they are expensive new. An easy way to check is to pull the spark plug out of the engine then reconnect it to the spark plug wire. Turn the engine over and check for spark at the end of the plug. WARNING: don't touch the plug unless you like pain. You can always buy a spark plug tester. Anyway, this will determine if you have spark problems with this cylinder.
Aug 22, 2017 | Daewoo Cars & Trucks
99 f250 no turn signal at factory trailerplug right side works fine checked all fuses ,?????
If the trucks left side works, then it is a wiring problem. If it works at the plug(test light) then the trailer light has a bad ground. If it doesn't work at the plug, then it is a bad power wire from the turn signal wire to the plug. Some times it is the plug itself. Truck or trailer. Corrosion.
Feb 27, 2016 | Cars & Trucks
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Glow plugs does not work.
check that the relay is working as the plug indicator gets the power after the relay . It may be a fuse . If the relay is ok then pull the Glo-plugs and have them check
Nov 21, 2013 | 2006 Tata Indica LXi
Best spark plugs for a toyota EE98
you can use what the factory has in the car or you can use ngk plugs,nipondenso plugs.ac plugs work well and have had good luck with champion plugs.these mentioned plugs will work well with your car.make sure you use the correct plug for your car as listed in the plug book which ever manufacture you choose.
Apr 04, 2012 | 1988 Toyota Corolla 4 Door
Glow plug burn out
DID YOU CHECK YOUR GLOW PLUGS AFTER REMOVING-CHECK EACH ONE MAKE SURE THATS YOUR PROBLEM AND NOT A BAD MODULE IVE GOTTEN A BAD ONE BEFORE THEY SEEM TO WORK FINE BUT DONT LET ENOUGH VOLTAGE OR TO MUCH VOLTAGE TO PLUGS.
Jan 17, 2012 | 2007 Dodge Sprinter
My speakers won't work.
Did you connect them to the computer through the proper plug? Sometimes people will plug them into the microphone plug instead of the speaker plug.
See if that is the case. Also, some sound cards may have a line out plug that will work as well.
Good luck.
Mar 04, 2010 | Audio Players & Recorders
The fan works great, but the light does not work?
are they both on the same switch?
have you checked the bulb it self or the socket that it goes into?
have you checked the plug in the fixture for the light? plug the fan into the light socket plug to check and do the same for the light - plug into the fan outlet...
have you checked both the neutral and the hot for the light plug?
Feb 18, 2010 | Broan-NuTone (668RP) Fan
Cigarette plug not working
Hi, the plug is kept in place with a nut that fits on the back of the plug. You will need to take the panel out in order to get to the nut. Before you replace the plug, on the back of the plug, you should see a grayish type of washer where the power cable connection is mounted. If you take that washer out, the plug should work again.
Sep 30, 2009 | 2004 Mitsubishi Outlander
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
