Wharfedale34 " flatscreen tv, hd ready and digital, there is sound but no picture, tv only 3 years old
Wharfedale tv no picture
Posted on Dec 05, 2010
  • ohmyword Dec 05, 2010
    NO PICTURE on a Wharfedale tv try shouting at it - I did and it works! Unfortuately keeps shuttung off by itself so may still end up in the bin!
My flatscreen tv has sound but no picture just a blank screen? what could be wrong
Most LCD TVs that are three years old or older that have the "sound but no picture issue" have experienced a failure of the LCD backlight circuit. Older units were fluorescent bulbs that used an inverter (ballast) to produce the light that shines through the LCD and allows you to see the image. These inverters fail after 3-5 years of use.
Oct 02, 2015 | Element Electronics Televison & Video
I have asharp aquos 45in flatscreen tv it comes on and the picture is fine but i have no sound what can be the problem?
The sound can be muted or the sound is directed to a port that you don't use. The main board controls the sound, so if it's not muted or misdirected, then replace the main board.
Mar 26, 2013 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Audio Players & Recorders
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Is the sony trinitron 23 inch tv hd ready
You will need a model number before anyone can even do any research.
In general, there were never many CRT (picture tube) TVs made with the required ATSC tuner and if your set is 5+ years old, it isn't compatible with digital reception.
Oct 11, 2009 | Televison & Video
Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
Jul 19, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio HDTV totally not workinig
It sounds like a problem with the power supply. I had the same thing happen on a TV that was only a couple of years old. It did the same thing that you have mentioned. Once in a great while, it would turn on, and then we'd just leave it on because we didn't know when we would be able to get it to work again. The problem was, to buy a power supply for it we could get another TV. It just wasn't worth it.
Your flatscreen might be under warranty. I would look into that.
Jun 11, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
Trying to find a port for sound input on Philips DVI LCD TV.
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
Feb 22, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Westinghouse Flatscreen TV
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Jan 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
PROVIEW 19" LCD TV - FLATSCREEN - KV SERIES
I have same problem, im goin to try this fix i found on youtube.. different tv but same problem
http://www.youtube.com/watch?v=_0175VbmV9M&feature=channel
Jan 08, 2008 | Proview HV-207 20 in. HD-Ready LCD...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
