Question about IDEAL VoltAware Non-Contact Voltage Tester
How do you change the battery in the Ideal Voltaware?
    Problem Solver:
  • 8 Answers
Depending on the model, where the yellow meets the gray it either pulls apart, twists apart or more likely the back where the pocket clip is, it should just pop off
Posted on Nov 01, 2010
I purchased new batteries for my IDEAL Ideal 61-065 Voltage Tester, but I still can't get the unit to perform contiunity checks. The light on the left will not come on. I want to ensure I have the...
IDEAL 61-065 does not have continuity function and therefore does not need batteries. If you have different model (like 61-076) then check if leads are good first.
Sep 16, 2011 | IDEAL 61-065 Voltage Tester
How do u change the batteries On a vole-test xl
there is a small clip at the back push both side in at ounce and the back will come away
best of luck
merry christmas
Dec 07, 2010 | IDEAL Vol-Con Xl Voltage/Continuity Tester
Ideal Vol-Con Xl Voltage/Continuity Tester: Where the heck is the "encapsulated screw on the b...
Encapsulated means that it won't drop out of the shell when you loosen it. There should be a screw that loosens so you can change the battery.
May 03, 2010 | Measuring Tools & Sensors
DC testing
No, you can't use an Ideal 61-065 tester to test a car battery. It is only for 100 volts AC/DC to 600 volts AC/DC.
A meter like this will work:
http://www.a1components.com/itemdisplayn.aspx?item=11307
Actually, the easiest way to test a car battery without a meter is to turn on the lights. If the lights shine bright like they are supposed too for a minute or so, the battery is maintaining the correct voltage.
Feb 20, 2010 | IDEAL 61-065 Voltage Tester
Recently new stater recfire battery oil &
Sounds like you have a problem with your mixture. If you changed your exhaust you have to change your carb jets
Sep 20, 2009 | Honda VT 1100 C Shadow Motorcycles
Battery backup problem.........
The ideal battery time which is mentioned in the booklet is for those condition when you use in normal condition like no screen saver, no memory card attached, no vibration, and many other features.But if you are using so and on the other hand many kind of software's are running behind.Then you can not get ideal battery timings. If your set is giving 12 to 24 hours in these circumstances then its working in good condition and if battery time is less then 6 to 8 hours then you have to change it with a new one battery.But the thing is that, your cell phone is ok and you need not to worry about it.
Hope this will help you to understand about your phone.
Thanks.
Oct 21, 2008 | Nokia N72 Cellular Phone
IDEAL VoltAware Non-Contact Voltage Tester Logo
350 people viewed this question
Top IDEAL Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an IDEAL Measuring Tool and Sensor Expert? Answer questions, earn points and help others
