Question about HP Compaq Presario V6000T Notebook
Dead compaq laptop, no boot activity
Powers on, .. lights come on, running finger down volume control bar produces clicks. no disk drive light flash whatsoever. no screen activity whatsoever.
will eject and accept cd-rom, drive spins up.
reseated ram and HDD. checked power supply for voltage
  • scowan Jun 02, 2008
    Powers up but the fan seems to drop off in speed, nothing boots and then it all just cuts off, but then tries to start again. This happens over and over and every once in awhile It actually boots up and comes on. Once on, everything works fine. Just a pain in not knowing if and when you will turn on your laptop and actaully be able to get work done.
  • 458 Answers
Larnold..Sounding like you need to check the LCD Power Inverter Circuit board.. this is located inside the screen a long rectangular circuit board that sends power to the screen backlight & Display Panel.. Could also be a Bad Backlight.. Try Booting it.. Hold it up to a light and look closely at the screen.. If you see a faint image but no light, it is the Backlight, if Just Black No Activity then its most likely the Power Inverter, OR a Bad Video Card.. You can test the VIDEO by Connecting the laptop to a Computer Monitor or similar with the laptops VGA Serial port.. then Use your function Key and Switch to 2nd Display.....(one of your F keys.. ).. If it Shows up on another screen, Its a Display problem and not the video card... Hope This Helps alittle.. Cheers
Posted on Jun 03, 2008
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
My compaq presario x-1000 hard drive light and dvd rom light flashes. Won't boot up.
Try disconnecting the harddrive from the case and then place it back in. if that doesn't help you may have a faulty drive, hows warranty? Compaq / HP would fix it for you free if you still have warranty.
let me know.
Thanks,
Ekse
Oct 31, 2008 | Compaq Presario X1000 Notebook
Laptop wont turn on, got green pwr and amb bat but will not fire up
Systems covered: All failing to boot without lighting up display.
Goal of this Solution: Try to determine whether system is (a) booting successfully while failing to light its display (indicating hardware failure in the display), or (b) failing to light the display due to failure to successfully transfer control to ROM BIOS (indicating a motherboard failure).
The fact that the Green power LED, and Amber Battery LED are lit seems to exonerate the laptop power supply (brick) circuitry. Even with a nearly dead battery, a Toshiba Satellite 1135-s1552 should work while plugged into a properly functioning brick.
Here's Toshiba support's (244 page) online PDF version of your laptop manual:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=434997&rpn=PS113U&modelFilter=1135-S1552&selCategory=2756709&selFamily=1073768663
If the HDD (hard disk) activity indicator LED is active after power-on, then your system has actually got past BIOS and is booting - your LCD monitor inverter circuit or Backlight may have burned out - and to use the system, you'll need to connect an external monitor to the RGB monitor port on the back of the system (see illustration on page 32 of User's Guide) to view system activity.
Alternatively, one may attach an analog TV, using the S-Video port on the back of the laptop (see illustration on page 32 of User's Guide).
Once an external monitor is working to display the ROM BIOS part of the boot sequence, you may find that the ROM BIOS is good enough to run a few BIOS-based diagnostics. Run them all - something may indicate the source of the boot failure. Ofttimes, enough of the motherboard remains good to provide interaction with the ROM BIOS, but some motherboard failure will subvert a full boot to Windows/Linux. An example of this type of failure would be a failure of the PCMCIA bus controller, which is vital for booting a disk-resident OS, but unaccessed (except by BIOS diags) when the user interacts with BIOS. Another common failure of this type is main memory (RAM) failure.
A working external monitor/TV also provides a chance to backup important laptop data to a flash drive, sky drive, or CD-RW discs.
If no HDD activity is seen after power-up, then either your BIOS is hosed (in which case you'll need a new motherboard), or another motherboard component is hosed (in which case you'll need a new motherboard).
You may want to transplant the HDD into a working PCMCIA-bus system (any laptop) to recover/backup your important data.
If someone recently attempted and failed to update the motherboard's ROM BIOS, then you know why the system is failing to boot and also failing to light the display.
Here's a link to a site with disassembly instructions for Toshiba laptops:
http://www.irisvista.com/
Most dead laptops (even those whose power supplies have been burned out by a nearby lightning strike with the system on 120 VAC power) will still have perfectly usable HDD module(s), and RAM memory cards, so that at the very least, these removable components may be recycled into memory reserves for your next laptop or sold (Ebay.com) to help defray the cost of a new system.
Dec 14, 2011 | Toshiba Satellite Computers & Internet
How to boot my laptop into usb drive
You have not specified your operating system. However I will explain how to do it with windows 7. First you have to create a bootable flash drive. Do it as follows
Format USB flash drive to NTFS format(For Win XP only. Vista users can directly format the USB drive to NTFS format) In your Windows, go to Control panel -> system -> hardware -> Device manager.
Under the disk drives section, right click on the USB storage drive and select Properties.
device-properties.pngGo to the Policies tab, select optimize for performance. Click OK.
device-policy.pngOpen your Windows Explorer, you should see the USB storage drive in the inventory. Right click and select Format. Select NTFS from the drop down bar. Click Start.
format-ntfs.pngFor Windows XP,
Download MBRWizard. Extract the zipped files to your desktop.
Open a command prompt (Start -> Program -> Accessories -> Command Prompt).
cd Desktop/MBRWiz2.0/
MBRWiz /list
Record the USB flash drive disk number
mbrwiz-list.pngMake the USB drive active.
mbrwiz /disk=X /active=1
For Windows Vista,
On the Start menu, navigate to the command prompt entry. Right-click and select Run as administrator.
vista-command-prompt.pngType
diskpart
list disk
Record the disk number of your USB flash drive.
vista-diskpart.pngSelect the USB disk.
select disk X (X is the drive number of the USB flash drive)
List the current partition. Record the partition number.
list partition
Select the current partition and make it active.
select partition Y (Y is the partition number of the USB flash drive)
active
list-partition-vista.png Creating bootable USB flash driveDownload Windows 7 iso (32-bit) file to your desktop (The download link is no longer valid).
Download and install WinRAR.
Right-click on the Windows 7 iso file and select Extract files. Extract the files to a folder (you can name the folder any name you want, but for illustration purpose, I name it win-7) in your desktop.
extract-win-7.pngIn your command prompt, cd to the windows 7 folder.
cd Desktop/win-7 (Change the destination to the folder that you have extracted)
cd boot
bootsect /nt60 X: (X is the drive latter of your USB drive )
bootsect-success.pngNow, copy all the files from the Windows 7 folder to the USB flash drive.
Reboot the computer. Remember to change the first boot device to your USB drive in the BIOS.
You should be able to install Windows 7 from your USB flash drive now.
Apr 26, 2011 | Sony Vaio Pcg-Z505N/Bp...
Compaq presario doesnt boot upon powering up
boot into the bios or if bios support diagnostics boot into that (typically F1 of F10 on power up) If that is not an option boot off the CD recovery disk and run diagnostics on the HD. Let me know we can take it from there.
Jan 30, 2010 | HP Compaq Presario SR1830NX PC Desktop
When attempting to start, laptop will not boot. I have tried all the different combinations for accessing the BIOS, but nothing happens. The hard drive light does not blink. I even tried a brand new hard...
if you cant hear the hard drive clicking or ticking, it sounds like theres no power going to it. you might be able to strip it down and see a wire or connector off.
Aug 21, 2009 | HP Compaq Presario CQ50-110US Laptop
On my lap top i receive message-"error loading operating system"
Trying booting into safe mode by pressing F8 while the computer is booting up.
Choose safe mode with the arrow keys and see if it boots that way.
Mar 20, 2009 | HP Compaq nx9030 Notebook
HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Feb 02, 2009 | HP Pavilion dv4000 Notebook
Compaq Presario V2000 will not boot
The clicking noise from the hard disk indicats that you have a intermitten faulty disk and therefore the computer sometimes boots up. If you manage to get the computer to boot, I would advise you to backup or copy your data. If you can't get the computer to boot up then the hard drive is dead.
You do not need to buy a new computer, just buy a new hard drive, replace the faulty drive and install your Windows operating system, all your device drivers (eg. audio, video, LAN etc.) and all your programs. You or a friend have a few hours of work.
Nov 22, 2008 | Compaq Presario R3000 Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
HP Compaq Presario V6000T Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
