Question about Canon MP610 Photo All-In-One Printer
When I do photo printing there is a line about 2 1/2 inches from the left side of the sheet all the way down. I have tried cleaning things but it does not seem to help. any suggestions would help.
Clean all rollers in the paper path..pay particular attention to those beneath the path that the carriage travels on
Posted on Oct 14, 2010
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Mutiple lines on right side of photo
try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
Nov 12, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Sheet feeder wheel marks on both sides of A4 photo prints
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost. no need to switch over to any other brand.trust me Kodak is really good.
Jun 22, 2009 | Kodak ESP 5 Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
A line is on my document when i print on my copier, how do i fix this?
TEST:
  1. Copy from the glass, is the line there?
  2. Copy from the Document feeder is the line there?
  3. Print a counter sheet, is the line there?
If 1 is false and 2 is true: Clean the little **** of glass at the left side of the scanner.
If 1 and 2 are true and 3 is false, You need to remove the platen glass (the big glass) an clean the mirrors. WITH THE POWER OFF
If all are TRUE you have an issue inside the Photo conductor unit and it will need to be serviced by a qualified person.
Apr 01, 2009 | Sharp AL 1631 Copier
Smudge mark 2-in wide down right side of each sheet of paper.
Generally speaking, any area that is darkened, is receiving less light. This can come from a lamp that is failing (similar to a fluorescent lamp used for lighting developing a dark end) or a mirror or optical lense that is contaminated with toner.
This may require some disassembly to diagnose and cure.
You may also want to visually check the fuser assembly (often accessible behind a door) to ensure there is no toner buildup on the affected side.
Mar 30, 2009 | HP LaserJet 3600n Printer
Dell Print Quality Problems: Horizontal lines On One Side
Try running a cleaning sheet through the printer. Remove the drum and check you waste toner (if that is built-in to your drum then skip this). If that gets full, then some of the bad toner can spill out creating lines/smuges. I would also use compressed air to blow out the inside of the printer where the toner/drum goes. That will help remove anything that is left behind after a replacement.
Also, check the settings in the print server for anything that will clean the printer/correct horizontal lines.
Mar 16, 2009 | Dell 3010cn Laser Printer
My HP Photosmart D7260 is not printing pictures
Ok! You didn't tell me how old is the printer, what type of paper and what size you tried to print so I'll do my best to help.
Please note:
  • The photo paper cassette cannot be installed when printing on paper loaded in the in tray.
  • The 7260 printer support 5x7 media only when printing from a computer with the printer software installed.
Loading 5 x 7 inch paper in the HP Photosmart 7260 printer
  1. Lift the main cover of the printer, and slide the paper width guide as far to the left as it will go.
  2. Lift the Out-tray and place a stack of paper in the In-tray.
    • Load the paper with the side to be printed facing down.
    • Load paper in the portrait orientation with the shortest edge feeding into the printer.
    • Do not use too much or too little paper. It may be difficult for the printer to pick up a sheet of paper when there are only one or two sheets in the in tray.
    • Use one type and size of paper at a time. Do not mix paper types or sizes in the In-tray.
  3. Push the paper into the printer as far as it will go without bending.
  4. Lower the Out-tray.
  5. Adjust the paper width guide to fit snugly against the edge of the paper without bending the paper. The paper width guide holds the paper straight as it feeds into the printer.
  6. Close the main cover.
Load 4 x 6 inch (10 x 15 cm) photo paper in an HP Photosmart
Use the photo cassette to load 4 x 6 inch (10 x 15 cm) paper. To print borderless photos, use 4 x 6 inch photo paper with a 0.5 inch tab (10 x 15 cm with 1.25 cm tab). This allows the photo to print without borders on three sides and with a small border on the bottom edge that can be torn off.
HP does not recommend printing borderless photos on plain paper. Also, remove any paper from the In tray before inserting the photo cassette into the printer.
1. Lift the top cover of the printer and remove the photo cassette from the sheath.
2. Place up to 15 sheets of photo paper in the photo cassette with the side to be printed facing down. For tabbed paper, insert the paper so the tabbed end goes into the cassette first.
3. Lift the main cover.
4. Slide the paper width guide all the way to the left.
5. Lift the Out tray and remove any paper that is in the In tray.
6. Line the photo cassette up with the far right edge of the In tray.
7. Gently slide the photo cassette into the printer until it snaps into place.
8. Lower the Out tray.
9. Slide the paper width guide to the right until it cradles the photo cassette, then close the main cover.
If the Out of Paper message appears on the computer and the product stops picking up or feeding paper.
Step one: Reset the product
1. Without turning the product off, remove the power cord from the back of the product.
2. Wait 30 seconds and then plug the power cord into the back of the product.
3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
3. Tap the stack of paper on a flat surface to align the edges.
4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
NOTE: Do not load too much paper in the product.
5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.
If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver
The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1. Open a document in the program being used to print.
2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
3. Click the Paper/Quality tab.
4. Choose the appropriate paper size from the Size is drop-down menu.
5. Choose the appropriate paper type from the Type is drop-down menu.
6. Click OK and then click OK again to print the document..
7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened.
Step four: Clean the rollers
1. Turn off the product and unplug the power cord.
2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5. Close the access door and plug in the power cord.
6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
If your product is less than a year old, don't worry, HP can trace the product when you provide the model and the serial number and will help you if it is in warranty. No prove of purchase required.
Jan 09, 2009 | HP PhotoSmart 7260 InkJet Printer
Canon MP610 Photo All-In-One Printer Logo
old marine
old marine
