Question about Neff W4380X1 Front Load Washer
Neff W4380 error or warning '03'
Hi there, my neff washing machine W4380 now displays what seems to be an error code accompanied by lots of beeping. It displays '03' on the red display.
Can anyone help?
  • 2 more comments
  • Anonymous Jun 30, 2008
    In the manual it says flashing 03 is blocked outlet hose, drain pipe or pump. I have cleaned pump as suggested and pump vanes easily move, water is pumping out but it continues to flash 03 when you start again. Any ideas?
  • Anonymous Sep 29, 2008
    Machine starts fine, fills and washes but doesn't drain. Machine makes a droning sound(towards bottom left hand side) before code 03 flashes. Have checked filter and outlet pipe!
  • Anonymous Jan 23, 2009
    ihave exactly the same model and fault any body who can help rectify thank you
  • charliedog17 Feb 01, 2009
    Ive tried all of the above however its still coming up with Error 3 on the second fill of the machine it seems to work at first but after the first pump Its comes up with the error any suggestions?
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Posted on Oct 11, 2008
My Neff integrated dish washer is displaying error code 9
Bosch and Neff machines generate the same error codes..
E9 is an overfill problem. It's putting to much water in and overfilling.
If you wanted to check yourself you will need to take off the inspection cover on the front and locate the pressure switch if it's at the front. If it's not then you will need to pull machine out and take off the side panels. When you have found the pressure switch it will have a thin hose going to it and it will be round and have a few wires on it. Take this hose off and blow hard through it to clear any muck out.
Refit the hose and retry machine. Hope this helps..
Apr 17, 2017 | Neff Washing Machines
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14? > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
Neff washing machine made beeping noise and
if it is shorting you need to get a service tech in . with its lights blinking it normally means a mains fault that can only really be fixed by a pro
hope this helps
take care
May 15, 2010 | Neff W5340X0 Washer
Neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
May 30, 2009 | Neff W4380X1 Front Load Washer
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
Error code e 10 means no cold fill.
Ensure that the water getting to the machine from the water supplies at the back. Check that the hoses are not bent or kinked and that the water tap is opened.
Try cutting power to the machine for ten minutes to reset the code.
If that does not work, then it is usually a faulty inlet valve stuck on closed on cold water.
Feb 27, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Jan 18, 2009 | Neff W5340X0 Washer
Error message
Switch machine off at the wall and leave off for 20 secs. Open the door. Switch back on again and close door firmly, giving the door handle an extra hard push. Should be o.k.
Mar 24, 2007 | Neff V4380X0 Front Load Washer / Dryer
Neff W4380X1 Front Load Washer Logo
1,071 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
