Question about Car Audio & Video
Everything is hooked up to my amp and im sure its all plugged in but the amp wont turn on ive tried 2 different amps but theproblem persists im outta ideas as to what could be wrong
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Is the rem terminal connected to the blue/white wire coming from your head unit?
Posted on Oct 15, 2010
My power acoustik bamf 2200 amp keeps blowing its fuses, why?
another couple of things is a bad ground wire. a sub going bad( causing a different ohm load then before) ive run into a bad fuse link in the amp before as well
Aug 04, 2014 | Power Acoustik BAMF2000/1D Car Amp
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
I hooked my Hifonics BXi 1610 Brutus series amplifier up to my 2 12" Kicker Solo Baric L7 subs. Everything turns on on the amp but its barely pushing my subs. Ive tried tuning it and it still doesn't push...
wire the subs if thair dual 4 ohm . in parallel. red to red and black to black. giving it a 2ohm load. do the other sub the same. and conect it on the amp . turn your gain about 12oclock and db level less than 12oclock and your frequnecy around 80-100. and that should work
Feb 18, 2010 | Hifonics BXi1608D Car Amp
Subwoofer popping noise
i had an amp do that a few years ago i did everything it turned out that it was the cdplayer. then agin myfriend had the problem and it was his altonator he had to get a ground loop isolator they are cheap
Feb 02, 2010 | Hifonics Brutus BXi 1206D Car Audio...
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
1991 buick park ave wont start
Typically,fusible links protect everything but the starter. I'd check them anyway & they're down at the starter. Also,make sure the engine isn't siezed,3.8's freeze all the time. Yes,that would mean the engine is toast. Also the transmission has a clutch in it & it could be locked in the on position. You can unplug the 4 pin connector in front on the trans & see if that makes a difference. Write back if you need more help
Jun 21, 2009 | 1991 Buick Park Avenue
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
2 12'' cvr kickers
ya u allreadyfound ound out the problem u have factory amps there u go after market
Feb 27, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
