Question about Hilti Drills
Hilti TE 10, appears capacitor (?) which slides onto switch mechanism has burnt out .Where can I get one in Melbourne, Aust. Hilti Aust tell me no parts available for this model any longer...Doug.
jgwhomeequip
  • 1902 Answers
SOURCE: Hilti TE-5 does not drill
Check the motor if the motor has power and then the gears are not working. If the motor doesnt have any power then you need to check for power. To get at the gears you are going to need to remove the chuck
Posted on Feb 18, 2009
  • 152 Answers
SOURCE: hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Posted on Mar 15, 2009
SOURCE: i need wiring schematics for hilti te 905 avr
Wiring schematics can be found by Hilti 1-800 number but they probally will not help you. The 905 is programed to shut down for service every 40 hours plus 10 warning. Then in my case I am stuck with a 200 dollar bill to send the tool from Winnipeg to Montreal for reprograming. Its a joke in my situation and its on me from Hilti, what a good name but what a scam.
Posted on Jun 09, 2009
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
SRF518
  • 232 Answers
SOURCE: grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
Posted on Oct 20, 2009
Testimonial: "thanks doc"
Hammer drill hilti TE 10 . Hammering parts broken. Replacement require.
Check the attached links, Contact Hilti and order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovative Solutions for Construction Professionals Hilti Canada
Results for My preferred Hilti Centers
HILTI AUTHORIZED DISTRIBUTOR AND RENTAL LOCATIONS
Hilti Tool Repair Hilti Canada
Mar 10, 2016 | Hilti Drills
Hilti TE-5 burnt resistor value
Hilti should be able to supply that information.
Jul 24, 2012 | Drills
I need a switch part 72442 for a old Hilti TE 60
that number sounds familiar, but I can't find a price I suggest going to Hilti.com and they have a store/dealer locator that you can call to get the par tthat you need. If you have any problems with call them at 1-800-879-8000 and they will be able to help.
Mar 02, 2010 | Hilti Drills
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Where can I find a switch for my Hilti TE 72 drill?
If you go to the German e-bay and search for hilti TE 72 , you will find answers to all your needs.
Rgds Egil
Oct 28, 2009 | Drills
Have a te6c and the chuck fell off- how to put it back on? looks like may require a large vise to press it on?? phil
pull back on the collar of the chuck and slide it on and then release the collar and turn till it locks onto the spindle.
Oct 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te 10 switch problem
www.hilti.com
Good luck
Aduz
Mar 14, 2009 | Drills
I need wiring schematics for hilti te 905 avr
Mar 14, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
144 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
