Question about Canon PIXMA iP4000 InkJet Photo Printer
Where is the waste ink absorber located and where can I get a replacement
    Brigadier General:
  • 10,406 Answers
Turn the printer off.
Disconnect the AC poewr.
Lift the lid covering the print-head mechanism.
Look where the ink-cartridges are "docked".
Below that point is the container that holds absorbent material that retains the waste ink.
Take your printer to a qualified technician, for replacement, and to "reset" the printer (to tell it that the new absorber is 0% full).
Posted on Oct 14, 2010
How can I change the foam pad that absorbes ink? What part is that called?
Hello
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
Message The waste ink absorber is almost full. Where is it?
You have to replace the waste ink absorber means that you have to replace ink cartridge.
Follow bellow steps to replace it.
  • First of all you will need these things napkin,replacement ink absorber.
  • Move the cartridge cradle center of the printing unit.Unplug the printer so that it will remain in its position.
  • Locate the waste ink absorber in their black rubber frame.It will likely be on the right side of your printer and will be located underneath the area where the ink cartridges rest when your printer is in standby mode.
  • To soak up any excess ink that may be in the pads by pressing it down onto the top of the frame, use napkin for soak up.
  • Pull the rubber frame free from the printer and carefully remove ink absorber.
  • Insert a new ink absorber pad into the printer by same inverse method.Be careful to pulling and pushing.
  • Hold the power button of your printer until it resets.
  • Wait for green power button then press and release power button again. It should blink for two to three seconds.It indicates that your printer is now reseted.
Thanks for using fixya.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My mp150 is showing to replace the waste ink absorber. I think its all about reseting the EPROM. Can i do it in home? Can it done by any sofrware?
Oct 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
How do I clean the waste ink absorber on a cannon ip90
We are not advice to clean WASTE INK ABSORBER.
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Ink waste Absorber
you are correct about the waste ink tank,did you check the pipe (if any)which use to carry the ink to waste tank,if it is clogged than also the problem will arise.
Mar 31, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon iP2000 Waste Ink Absorber - where is it for washing and replacing?
I found it under my ink cartridges in my Canon iP2000 printer. Trying to losten it for cleaning, it came out in my hand, I washed it and replaced it with a tiny amount of glue. After resetting the program, it is working again.
Feb 11, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
138 people viewed this question
old marine
old marine
