Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
B&D CMM1000 Mower
My mower is great! After several years of use it now shuts off after about 5 minutes of use. If I let it sit a few minutes it will run again. I recently replaced the batteries thinking that this may be the problem. The mower is much more powerful with the new batteries but it still has the problem of shutting off after a few minutes of use. The motor is not hot and nothing seems to be overheading. Suggestions? I bought the mower as a reconditioned unit.
  • Anonymous Jun 14, 2008
    I have a CMM1000 mower as well. Just recently when I attempted to start it after it was charged it would not start. I banged the rear wheels of the mowers and it started but it seemed to run slow. I stopped it and started it up again and it ran normal. After doing this a couple of other times the mower now will not start at all. I have opened the top cover and looked at all of the connections and they are all solid. Not sure what the problem is. Any other suggestions on what I should do to resolve this?
  • dthomp15 Jul 08, 2008
    Yup! Cuts off after running for awhile. Seems to be related to the load on the motor (LENGTH of grass.) After an half minute or less, it will start again. You can hear a slight "click" of a breaker resetting. After this has happened several times, the time before it stops shrinks and the length of time to reset gets longer. Frustrating. Let it rest for an half hour and the time intervals become more tolerable. Still not the pleasurable experience we had last year.
    I have not taken it apart to see if there is a circuit breaker accessable for replacement...but will soon. Any info would be appreciated.
    Champion:
  • 313 Answers
Convert your mower to cmm1200. you needs parts 905058-81 to convert it.this to elliminate the circuit board & it's easy to install just follow the instruction. circuit board was on recall depend on the date code of the mower it is also no longer available.
good luck.
Posted on Jun 02, 2008
  • mr aicnelav Jun 02, 2008
    correction on the parts # 905231-38 service convertion kit.
  • mr aicnelav Jun 19, 2008
    check if the switch cable in not kink,pinch or damge. it will affect big time not to start properly.
Huskee 16 hp Tecumseh starts and runs great but
When it shuts down check it for spark. You sound like you may have a weak coil. OR
You might have water in your fuel and it only runs until it hits the water level in the carb. You can try draining your carb *(do this when mower is cold...never drain gas from a hot mower!) and see if the mower runs longer. While you are draining your fuel you can check the float level too. A float that closes too early or that is partially obstructed might only let in enough fuel to run for short periods. Then, your three minutes of sitting is just to let the carb bowl refill. When you remove the carb bowl let the float hang down and note the fuel flow. Is it fast? Or is it just a slow drip? If it seems slow you should work the float up and down a few times to see if the flow improves. If it does improve consider draining all the fuel out and cleaning the gas tank.
Good luck and be careful!
Jul 16, 2010 | Garden
Cmm1000 electric lawn mower grass bag needed
I would recommend checking eBay as you can get these for almost 50% off your purchase. Visit the manufacturers website and get a part number for the bag. Use the part number to search on eBay.
Hope this helps!
Oct 20, 2009 | Black & Decker 19" Electric Lawnhog...
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
B&d cmm1000
see if ur mower is cmm1000 type 1 to 4.this unit are recall for
board. see service center to upgrade the unit to CMM1200. if ur battery are not holding charge need the battery is not parts of the recall.battery will last 3 to 5 yrs apx.
Aug 15, 2008 | Black & Decker 19" Electric Lawnhog...
B&D cmm1000 cordless rechargeable mower
see www.blackanddecker.com for CMM1000 type 1 to 4 / recall.
if ur mower is under that type then see service center for recall. board are recall & needs convertion to CMM1200
Aug 04, 2008 | Black & Decker 19" Electric Lawnhog...
Mower
if you mower is cmm1000 type 1 to 4 its under recall for board problem. if you have type 5 its not affected. see www.blackanddecker.com/recall
Jul 24, 2008 | Black & Decker 19" Electric Lawnhog...
B&D Mower CMM1000
thats the CMM1000 type 4. the unit are recall.go to any service center & ask for conversion to CMM1200.
Jul 18, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
490 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
