Question about BenQ PB6200 Multimedia Projector
I have a pb 6200 the picture has gone very dark even though i have tweaked the contrast and brightness, is the bulb going ? or can i reset the bulb timer i do not have a remote control
  • 1 more comment
  • grumpydad360 Oct 14, 2010
    not sure the advice i have been given is right but i am sure you can reset the used hours on the bulb timer so it doesn't go into safe mode
  • grumpydad360 Oct 15, 2010
    Sorry to be a pain, i have no remote for this model how could i check the hours manualy
    thanks - Trevor
  • grumpydad360 Oct 16, 2010
    Thanks guy's you have all been very helpful, I have just been unlucky with a second hand purchase - therefore a new bulb it is.
    Kindest regards - Trevor
    President:
  • 1,216 Answers
Bulb life is rated at 2000 hours and it is the decline period for your bulb.You eventually had to purchase a new bulb ans this is the only solution......
Thanks
Posted on Oct 15, 2010
    Genius:
  • 1,016 Answers
Yes the bulb is on it's way out, you can check the hours the bulb has done and if it has exceeded 1500hrs then you will need to replace the bulb.
Hope this helped, let me know if you need more information.
Thanks
Jason
Posted on Oct 14, 2010
  • Jason Maurirere
    Jason Maurirere Oct 15, 2010
    You should have a hour meter on the projector in the back of it or on the top, if not then you can only see it on the menu screen, but you may not be able to access this without the remote.
  • 2,382 Answers
Hi, there is no way to reset the bulb timer even if you have the remote control with you. Just as you have said, the bulb is fading out and you need to replace it...
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
The picture is very dark and it has a new bulb
Unfortunately, this is not an easy diagnosis. It could range from being an issue with the brightness level (which can be accessed from the menu) or an internal processor defect.
First access the menu and verify the brightness levels and contrast levels.
Next, make sure the problem isn't in a single input by changing the inout of the component that you are viewing. Component cable inputs are notorious for going bad so try an HDMI if one is available or even a basic composite cables will work for diagnostics.
If the picture is still dark after this it's probably a processing problem and will require professional maintenance.
Jun 27, 2011 | Televison & Video
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
THE PICTURE ON MY ZENETH PV6067DT TV WILL NOT GET
Make sure there is no light shining on the electric eye it will adjust brightness automatically also check bulb for dust and dirt
Nov 30, 2009 | GPS
Ibm thinkpad monitor very faint, images are barely visable.
It seems that the contrast and brightness are out. On the monitor, press the Menu button. Then go to the brightness and reduce brightness and set the Contrast to a little more. You will have to tweak these two settings to get the correct picture. First set them at default and the go up and down to get the right picture.
Nov 24, 2009 | IBM Computers & Internet
Display screen to dark
Hello
First thing you need to do is,inside where you can see the screen, search for the brightness and contrast options in your cameras menu. Once you know where they are go outside and try to tweak it until it works. Usually you would want a higher brightness, then just adjust the contrast until your satisfied.
Hope this helps
-Chris
May 01, 2009 | Cameras
Why has the picture on my tv gone too dark to
have sound but picture is too dark to watch on tv
Mar 21, 2009 | Televison & Video
BenQ PB6200 Multimedia Projector Logo
169 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
