Tv does not power up properly
Jensen welcome screen does not go away upon tv power-up. no buttons on the tv or the remote function
    Novelist:
    Champion:
  • 203 Answers
Sounds like it is in demo mode. First check in the owners manual for auto demonstration, then try unplugging the set for 5 mins. If that doesn't correct it call the store you bought it from and see if the salesperson knows how to turn off auto demo. If all else fails, contact the manufacturer for help.
Posted on Jun 02, 2008
Black screen covers screen on a jensen je26f0
see this troubleshooting chart and fix it.
God bless you
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Oct 15, 2013 | Jensen New Original JE2610 Remote Control
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
BLACK SCREEN NO AUDIO POWER LIGHT IS ON
Since the screen is coming on I do not think it is a problem with the power supply. It sounds more like a problem with the audio/video main board of the set. Is the set under warranty?
Jul 13, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Power on - Screen Black non responsive
Hi...
Look into getting the main power supply replaced
Check the web for someone near you
Apr 22, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My tv is shows a blue screen. My tv does not respond to the function button's and there is a lock in the upper left hand corner of screen of JENSEN 27" tv
To remove the lock on the Jensen simpy press and hold the Display Button on the remote for at least 3 seconds whilst pointing it at the TV.
The lock will be removed and the TV will resume normal operation.
Please do leave a vote for the solution. Thanks for using FixYa
Jul 03, 2009 | Mitsubishi CS-26201 TV
Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
May 18, 2009 | Jensen Televison & Video
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
FIX:
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
TV Problems
If you hold down the display button, you will lock the tv. Hit the power button and you will prevent anyone from wathing the tv without the remote. The only way to unlock it is by turning the power on with the remote of course (the blue screen should show) and hold down the display button.
Mar 16, 2006 | Jensen TS2750J TV
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
