Question about Coleman 3AAA LED Headlamp
I just bought a Coleman LED Headlamp, unscrewed the end of the "BATTERY" case & cannot see how the 3 AAA batteries fit in!! Can you help with this?? Thanks
3 Suggested Answers
  • 3 Answers
SOURCE: I just bought the coleman
In the headstrap is a plastic 'key' that you use to remove the battery cover (opposite side of the headlamp from the switch). Once you remove the cover, you can shake the headlamp to let the battery cartridge slide out of the headlamp.
Pay close attention to which way the batteries go in--if you put a battery in the wrong way you can easily bend the springs inside!
Posted on Dec 28, 2010
  • 3 Answers
SOURCE: i JUST bought the coleman
TO INSTALL OR REPLACE BATTERIES
1. Rotate body of headlamp until lights are pointing down and battery cover tab is to the front.
2. Insert edge of buckle on headband or a coin under tab and twist to unlock and remove battery cover.
3. Install 3 "AAA" cell batteries in the correct orientation as shown on the battery housing. Make certain all 3 batteries are installed
correctly.
4. Replace battery cover by first inserting the tabs on the back of the battery cover under the back edge of the battery housing, and
then rotate down until battery cover snaps into locked position.
For the manual: http://www.coleman.com/coleman/images/pdf/4343-704.pdf
Posted on Feb 28, 2011
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
How to chnage batteries
The four AAA alkaline batteries are securely held in a battery pack attached to the tailpiece, which incorporates the T7's push button "Quick Cycle" selector switch. Unscrew the tailpiece, remove battery cartridge and refill with 4 "AAA" batteries. Slide the cartridge back in the torch and screw the tailpiece back on.
Kevin
Dec 18, 2014 | LED Lenser T7 Flashlight
Fenix hp11 headlight
Hi, I have some experience with this unbekievable good headlight(when it works).
I had a hp10 what started to stop more and more.
After a while it wasn't going on.
5 years warrenty, so i got a new one, the new model.hp11
The main problem is the wire from battery case and the head led.
When there a litte damage inside this wire, light goes of not going on it selfs when it connecting again. After a while it will not work any more.
(if you have a welding station you fix it your self (battery case,can go open by unscrew the wire entrance.)
Chack battery case if the springs are all still connecting the battery.
If you put in one battery false on there is short cut and al sprigs get so hot they will shrink. And stay in that position..fix that your self or ring/ contact the shop you bought it.
There 5 year of garrantie.
wonderfull
Jul 25, 2012 | Fenix Camping, Backpacking & Hiking
I JUST bought the coleman mini led headlamp and i don't know how the batteries are supposed to go in. the back will not open and there were NO instructions.
correctly.
Feb 21, 2011 | Coleman 3AAA LED Headlamp
I can't seem to get the "small" screws off to put the batteries in!! Please Help!! Thanks:)
You don't remove the screws!!! Use the plastic 'key' that is in the headstrap to remove the cover (opposite side of the headlamp from the switch). Then shake the headlamp to allow the battery cartridge to slide out.
Dec 27, 2010 | Coleman 3AAA LED Headlamp
How to turn on Model No. 3000001019 Coleman headlamp. I got the batteries in but it does not go on. How do I turn it on?
Make SURE you have the batteries in the right way. If you have a battery turned around it won't work, plus you will likely bend the spring inside and then be unable to get the battery in the right way.
Dec 25, 2010 | Coleman 3AAA LED Headlamp
How do you install the batteries
If it is the same as the Coleman headlamp I just bought, it claims to have a "easy slide out battery cartridge" On the strap there is a plastic key to unscrew the lid where the batteries are but this doesn't allow you to access them. When you bang the entire thing in your hand to make the cartridge slide out it may not come at first because it is stuck. I partially unscrewed one of the tiny screws on the top of the battery cartridge and pulled on it. This caused it to slide out of the headlamp and I could load it with batteries. I then rescrewed it in gently as its kind of fragile. After this I could get the cartridge in and out by simply tapping the light in my hand with the lid off. The light works great now. Since the screwdriver is so tiny that you need to do this, see if you have a eye-glass repair kit lying around. It may have the size you need.
Nov 07, 2010 | Coleman 3AAA LED Headlamp
I just bought the coleman Max mult-colored headlamp and i cant figure out how to put the three AAA batteries in
Oct 26, 2010 | Coleman 3AAA LED Headlamp
How to install batteries in coleman axis headlamp
Side panel comes out by turning (if you look on head strap, one of the ends says Key/battery. You can insert that into the side battery compartment and turn counter-clockwise). After you have that cover off, simply take something like your knife and pry it from behind the battery case and it will slide right out.
(O) is what you will see if you're looking down on it. The circle in the middle should have 3 tiny screws in it. Stick your knife between the O and the ) and pry the O out. Hopefully that makes sense. You could also just pop the battery cover off, and then hit the flashlight into your hand so that you knock the battery compartment loose. Then you don't have to pry anything. But that might damage the LED...probably not though.
Dec 24, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman 3AAA LED Headlamp Logo
118 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Ted Maxwell
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
