Question about Maytag Neptune FAV6800AW Top Load Washer
Doesn't spin, dc and uc codes - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
See this post Clutch Fix
Posted on Oct 21, 2010
What's the purpose of the tub displacement sensor
To detect excessive wash tub movement and shut down the wash cycle. Here is a copy of my post from a real DIY forum;
Google this Neptune TL Washer FAV6800AWW 5 post down.
Here ya go.....in this post I discuss the issue related to unbalance error codes DC and UC;
Your FAV6800A or FAV9800A is going off balance with DC or UC unbalance error codes during spin cycle and you see/hear the wash tub banging around at the start of Spin Cycle of the wash cycle or a Spin Only cycle. If this is the condition the TDS (Tub Displacement Sensor) is working as designed and signaling the Control Board properly of an unbalance wash load condition.
The Control Board receives a varying D.C . Voltage from the TDS sensor and if the out of range D.C. Voltage limit continues the Control Board will halt the Spin Cycle and try to redistribute the wash load. If you are interested I will show you how to monitor the TDS input to the Control Board with a DVM.
The Control Board then starts the Spin Cycle again. If the wash tub/basket out of balance condition continues the Control Board will attempt another redistribute of the wash load. After several attempts (4 to 5 I believe) the Control Board will shut down the Spin Cycle and send a error code DC or UC to the LED display of the FAV6800A, my machine type. And I believe a text statement to the LCD screen of the FAV9800A machine i.e. something like "Unbalance Condition" I'm not sure what the text message is.
If you need help open a post in that repair forum and I will try help you through your issue.
The forum is free and my time is free I just don
Feb 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle is not completing, code DC appears.
I have a DC code that comes up when the washer is in the spin cycle.
See this post for dC/uC error code in Spin Cycle for the FAV6800A or FAV9800A.
http://www.fixya.com/support/t2070219-model_fav6800aww_will_not_pump_water_out
Post back if you have questions or concerns.....Rich
Mar 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont Finish Spinning stops and Flashed DC
If the machine type is a FAV6800A/FAV9800A see this Clutch repair post if you want to DIY. You will find links to the Service Manual and parts info if needed.
You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of max Wash Tub movement and the Control Board shuts the Spin Cycle down……..so thebTDS is working as designed.
The machine will make several attempts to redistribute the load before error code generation failing with dC or uC error codes.
Post back if you have questions any DIY'er with basic skill sets can do the Cluch maintenance/repair.....Rich
Jan 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have an error code uc in the spin cycle what could be causing the problem?
uC = a continuous unbalance condition of the wash load.
Because you are posting in the Fixya Neptune FAV6800AW Top Load Washer forum I’m going to assume your machine type is a FAV6800A or FAV9800A.
For those machine types I feel you are experiencing a clutch malfunction. Can you confirm the machine model number and let me know if you want to try a DIY repair. You only need basic hand tools and skill sets to repair. See this post for what is involved and this a most recent post of a forum members repair for a dC error code condition in Spin Cycle which related to the uC error code in Spin Cycle.
Dec 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
UC code on my Maytag Neptune Washer FAV6800WW
HI. this uc code represents a no spin state of the unit. this is caused by a faulty Motor control assembly. you will need to replace the Motor control assembly. this will fix this issue and, restore the normal actions of the unit.
This Motor control assembly will cost about $219.00.
Jun 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Receive code "dc"...water will not drain and tub will not spin properly
This is my failure resolution with DC/UC error codes a common problem with this model;
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
I found a Service repair manual on this site search for this; FAV6800 Manual
Sep 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
