Question about Refrigerators
Does maytag make a garage kit for their refrigerator?
I need to replace the refrigerator from our garage. I bought a simple kenmore with the freezer on the top, only to find out that this type of freezer/ refrigerator will not work in the garage. I need to...
We have the same problem. Sears told us we needed to get a garage kit. It is a small heating element that installs somewhere around the compressor. Cost $20-$30. Just orderd ours today.
Jan 06, 2011 | Kenmore Refrigerators
My freezers out in my garage and my foor is not staying frozen y is this
its to cold in your garage for the refrigeration system to work properly. the tempature in the area of the unit needs to be at lest 50
Dec 09, 2010 | Maytag Refrigerators
My KSRB22FKBL14 KitchenAid side-by-side fridge caught fire (start relay on compressor). I understand that KitchenAid fridges are made my Whirlpool/Maytag. Whirlpool/Maytag has a HUGH recall right now...
the problem is the same as maytags but it may not be a recall model . relay is white . the new style are blk . you can purchase the new relay kit.( what is a start devise .kit / changing it will solve the problem .. also you should contact whrlpool .. mm
Aug 12, 2010 | KitchenAid KSRS25ILSS Side by Side...
Is there a garage kit for my kenmore refrigerator?
Assuming you are describing a standard domestic Kenmore refrigerator, and you are asking about an add-on "kit" that will permit the unit to operate in a cold garage, the short answer is no. Kenmore (Sears) makes a refrigerator that is rated for garage use, but it's not a big one.
However, if you are handy, you can install some "bat" type fiberglass insulation under the unit around the compressor being careful not to obstruct the fan or any other moving parts. This will help hold some heat in the compressor area. You will need to remove the insulation in the warmer months so the compressor doesn't overheat.
If it's REALLY cold in your garage in the winter, you could try disconnecting the condenser fan, but you should keep an eye on the unit to see how it performs. The condenser fan MUST be connected if the temperature in the area exceeds around 45 degrees.
Jan 10, 2010 | Kenmore Refrigerators
How do I repair broken wall pins that hold up the shelves in my 10 year old maytag refridgerator
I believe maytag makes a repair kit take your model number and serial to a local appliance parts store. or call maytag good luck
Jul 08, 2009 | Maytag MSD2542VE Side by Side Refrigerator
Cold garage interferes with top freezer keeping cold enough
Sorry it took awhile but there is not a cold area kit for this refrig available. it needs to be used in a controlled climate so that the controls will operate properly thanks for your patience. Peyton
Jan 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Garage frig
the garage kit, if even available for your unit, works pretty well, but your right in extreme colds your outta luck, other then buying a refrig designed to work in garage, yoll need to either insualte and heat garage, or wait till spring sorry.
Jan 11, 2009 | Kenmore 63822 / 63824 Bottom Freezer...
Side x side Kenmore refrigerator built by Whirlpool in cold garag
there is no such kit available for whirlpool side by sides, not enough of a call for a kit to be designed, iim assumin ghtat the unit is in a garage, they will try to sell you an refrig built just for that application, but its a bit pricey.
Jan 09, 2009 | Whirlpool Refrigerators
Keep garage refigerator/freezer cold in winter
is it a frigidaire model by any chance?? if so you can call the manufactue they do have a garage kit, to help the machine run at a lower ambient temp.
Dec 04, 2008 | Refrigerators
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
781 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
