My television is an Olevia LCD model number 542-B11. It was dropped on it's power button. After taking it apart I noticed that the push-button switch that controls the power had been obliterated. The button had the marking 18v HT on it, and the actual part number for the IR/Power board itself is EPC-P501801-000. I'm not sure where I can find a replacement part for either of those two items, or how I can go about fixing it otherwise.
  • Doinker Oct 17, 2010
    I tried shorting the contacts but it still doesn't seem to be working, maybe the board will only accept a signal at a specific voltage? Also, I tried to get in touch with Olevia but to no avail.
  • Doinker Oct 21, 2010
    Tried shorting it, and it still wouldn't work. I also can't get in touch with anyone from syntax-olevia. Any other ideas?
  • 12,061 Answers
Ok, this button is usually a simple Push to Make switch, almost ANY switch that would momentarily short out the contacts will work, there is nothing special about them, indeed you may be able to activate the switch, by simply shorting out the contacts on the PCB, as long as it doesn't have 120V on it though, usually NOT, but check anyway.. The switch was rated at 18V, so it indeed looks like a low voltage switch...
Obtaining an exact replacement may be difficult, your best bet would be to contact Olivia direct, weblink below. They either can sell you the part, or put you in touch with a parts supplier.
http://www.olevia.com.hk/home.php
Posted on Oct 15, 2010
542-b11 will it work with digital antenna
Refer its user manual [specifications] and see whether the tV can process digital signals. If it has ditgital processor inside, you can see it there in its specifications.
Apr 27, 2012 | Olevia LT42HVi 42 in. LCD Television
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Model 542-B11 External signal won't display (settings menus work)
Well first of all yo can try to reset your TV, just turn it off for more the 24 hours and then turn it on again, it helps you to reset your TV. (turn off your TV from main housing not only from the TV power button).
Let us know if this helps....
Good Luck!!
Thanks
Dec 14, 2009 | Televison & Video
In need of a owners manual for a model 542b11 42 in Olevia brand TV
I have the users manual. Leave me your email address and i`ll send it to you, it is about 6 megs in pdf format.
Dec 02, 2009 | Olevia LT42HVi 42 in. LCD Television
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Sep 10, 2009 | Olevia Televison & Video
I have an Olevia 542-B11 TV with remote control. I have Directv and always had to use (2) remote controls. My dog chewed my Olevia remote control, now I can't turn the TV on or off, adjust volume, switch...
its hard to find a remote that will work an olevia , since this brand is new and alot of manf. that make universal remotes have not updated there system..
This company called Amergence Technology sells the Olevia Remote and will control any olevia television.
Contact them at 866-965-3842 (just ask to purchase a remote)
Jun 29, 2009 | Olevia LT42HVi 42 in. LCD Television
Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Jan 21, 2008 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
