Question about Karcher G 2600 VH Gas Pressure Washer
Pressure cuts in and out won't stay at full pressure
    Scholar:
  • 100 Answers
2000 Mitsubishi eclipse the oil light came on and my car shut down. I added 1 quart of oil and it was full but the car still won't start.
The oil light does not indicate the car is low on oil (based on your discription) it indicates the oil pressure is low, the no start is most likely due to this low pressure and the fuel pump has been cut off to prevent damage to the engine from low oil pressure. Please have a shop locate the cause of the low oil pressure warning and repair it as needed. It could be a false light or a real one, which means if you drove it very far you may have damaged the engines bearings.
Sep 24, 2012 | Cars & Trucks
AC compressor cuts in and out and won't stay engaged?
that means there is not enough pressure/refrigerant in the system. add a can of r134 and it may stop doing it
Aug 30, 2012 | 1993 Ford Ranger SuperCab
Fuel problems
Sounds like the fuel pressure regulator is stuck in the open position.I am trying to remember if this engine(Vortec?)has a return line to the tank.If it does,try disconnecting the return(smaller) line,and use something to plug the fitting on the outlet of the fuel on the intake(Use a piece of fuel hose and a bolt_make sure you use a hose clamp,as there is 50 PSI of pressure)
Dec 31, 2011 | 1995 Chevrolet Blazer
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
My truck won't strat till I spray starter fluid then it will not stay running when I am giong up a hill it will cut off what should I do
sounds like you have a weak fuel system. to start off, i would have a fuel pressure test done to the vehicle to make sure the pump is working correctly
Sep 13, 2011 | 1994 Chevrolet S-10
Backfiring, will not stay on. 94' cobra
first thing is check fuel pressure. or blow thru the fuel filter to see if its clogged. If the filter is OK you still need to check pressure.
Dec 01, 2009 | 1994 Ford Mustang
Shallow well pump cycles on and off quickly? Stays on while water is running than shuts off when valves are closed.
Do you have a tank in this system? If you don't, this is the way the well pump will operate.
If there is a tank, it will have a pressure switch on it which controls the pump -- it'll cut the pump on when the tank pressure drops to 28 psi, and cuts the pump off at 40 psi.
If you have a tank, the pump behaving as you describe indicates there is something wrong -- need more info.
May 05, 2009 | Flotec Corrosion Resistant Shallow Well...
Hard to start and won't stay running
Put fuel in it,then check the fuel pressure with a gauge. The tank unit maybe giving a false reading.
Apr 18, 2009 | 1993 Buick Riviera
Karcher G 2600 VH Gas Pressure Washer Logo
189 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
