Cuisinart CBK-200 Bread Maker Logo
Posted on Oct 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't scroll through the menu to select the gluten free setting. what do i do????
Daryl Nash
Level 3:
  • Cuisinart Master 1,280 Answers
  • Posted on Oct 17, 2010
Daryl Nash
Cuisinart Master
Level 3:
Answers
1280
Questions
0
Helped
323397
Points
2747
Can you scroll through the menu to select any program or is gluten free the only one you can't select?
Can I make gluten free bread in the TR845?
Yes. Almost any bread machine can make a gluten free bread.
The key is to select teh correct settings to allow it to rise dequately but not too much.
Try these recipes:
Gluten Free Bread Machine Recipe White Bread
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
1helpful
Try these recipes:
I heard that the Promax bars are really delicious. The problem is that I cannot consume anything with gluten. Which Promax bars are gluten-free?
I got this information from their official website: "Promax Core, PromaxLS and Crunch bars are certified gluten-free by the GFCO (Gluten Free Certifying Organization). The GFCO defines the standard for gluten-free as less than 10 ppm which is half the proposed FDA standard of 20 ppm gluten. GFCO certification requires that each ingredient has been evaluated and approved by the GFCO as gluten-free. In addition, strict standards have been set in the manufacturing facility to assure no cross-contamination. Finally, the finished product is tested as final assurance that Promax bars comply with the GFCO certification."
1helpful
4answers
Gluten free bread
My breville instruction book says that the gluten free bread recipes are all to be done on the 'rapid' setting but that is the breville booklet recipes. I do know the time delay cannot be used. K
1helpful
Hello! My panasonic sd253 wont change program! I want to bake a gluten free bread. I click at "start" , and then when I click on "select" because I want to go all the way down to...
Push select again and again until you get to the gluten free program. The Start button should be pressed after selecting the "program" or "course".
1helpful
I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
2answers
Need to make gluten-free bread
bobs redmill gluten free mix for bread machines. we just use the standard bake setting but select B for doneness level. found it gets a little too dark on A.
Baking gluten free bread in model 5890
good day,
hope this link below will solve your problem.
Set your bread machine program for 1.5 loaf medium crust. I used the gluten-free cycle on the Breadman; if you don't have a gluten-free cycle, I believe a rapid rise cycle will also work.
Check the dough after a few minutes of kneading- it should be closer to a muffin batter than bread dough, soft but not too wet. Adjust dry to wet ratio with a tablespoon of flour or warm liquid, as needed. Humidity influences the dough. As does temperature (your bread will rise higher on a hot day).
If you like a crusty loaf, remove the bread from the pan and place it in the oven at 350 degrees F for an additional 10 minutes- keep an eye on it and don't let it get too brown. It should be a light golden color.
Cool the loaf before slicing for best results.
Enjoy fresh from the oven- the first day (as with most gluten-free baked goods) has the best texture and taste
Read more: http://glutenfreegoddess.blogspot.com/2009/02/delicious-gluten-free-bread.html#ixzz0ZZASptEr
Calender problem!
To add, change, or delete a Calendar appointment from the handheld, follow these steps: To add an appointment
  1. From the Home screen, press the Menu key.
  2. Scroll to and select Calendar.
    • NOTE: To select, press the trackball.
  3. Scroll to and select desired date and time.
    • NOTE: Selecting exact date and time will default to that date and time when the appointment opens, however these fields can be changed so any date and time can be selected.
  4. Enter a Subject.
  5. Enter a Location.
  6. If desired, select All Day Event.
  7. If desired, scroll to and set the Start and End date and time.
    • The 'Duration' should update accordingly.
  8. Scroll to and set Time Zone as desired.
  9. Scroll to Show Time As.
  10. Select one of the following as desired:
    • Free
    • Tentative
    • Busy
    • Out of Office
  11. Scroll to and set Reminder time as desired.
    • The options range from None to 1 Week.
  12. Scroll to and set Recurrence as desired:
    • None
    • Daily
    • Weekly
    • Monthly
    • Yearly
  13. If desired, select Mark as Private.
  14. If desired, select Notes, then type any notes.
  15. Press the Escape key.
  16. Select Save.
To change an appointment
  3. Select the appointment to be changed.
  4. Adjust any options as desired.
    • NOTE: The available appointment options are listed in the portion above.
  6. Select Save.
To delete an appointment
  3. Select the appointment to be deleted.
  4. Scroll to and select one of the following:
    • Open the series (for reoccurring appointments)
    • Open this occurrence
  5. Press the Menu key.
  6. Select Delete.
  7. Select Delete again to confirm.
I would recomend that you powercycle your phone regularly. If you have anymore questions feel free to ask me.
Breadman TR875 Gluten Free Setting
 Mine won't either. I do not like the gluten free setting. If you read the times in the catalog the gf setting does not allow a rise program. I have been baking gf bread since last oct. I use the rapid cycle and all my bread comes out great.
Top Cuisinart Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Stan Ford
ADMIN Eric
ADMIN Eric
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
