Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My 500gb hard drive is partitioned into 2 sections but I can only open one, I get an i/o error message when I try to open the other side
  • Ethan Semone Oct 20, 2010
    yes, after many starts and stops that did the trick.
    Thanks so much!
    Ethan Semone
  • 13,433 Answers
You need to run a checkdisc on the 2nd partition it should help.
Hold down the windows key and press r. Write CMD and click OK.
In the black CMD window you need to write CHKDSK /F /X R:
You need to replace R: with the drive letter of the partition / section that does not work. you can see it from my computer or computer. for example G: Also notice the space between CHKDSK and /F, and /X AND another space between /X and The letter.
The scan will take some time but hopefully the drive should now work.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Posted on Oct 14, 2010
Data error cyclic redundancy
Hi
There are several situations that might have caused a damaged to the driver.
DATA ERROR CYCLIC REDUNDANCY might have been caused by a Virus attack. And in those cases, you will provably end up buying a new hard drive.
How would I know that? Well, just check your memory and remember if you had been doing some Internet search/chat/downloading some stuff/visiting unknown sites, etc., prior to the damage.
It ussually happens when you are using Chat programs, in which you may have received a file or a link to visit to
(most likely the virus made an unrecoverable damage on the main section of the drive, the MBR - Master Boot Record)
Feb 07, 2014 | Western Digital My Passport Essential...
Tip
Using Windows Disk Management Utility to Manage Internal and External Disks
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
The Disk Management utility can be accessed in two different ways.
#1- You can open the Control Panel,
Click on Administrative Tools,
Click on Computer Management and the Computer Management window will open.
#2- Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a “Drive” and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”)
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter “C”.) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters “F” or “G”. In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
on Jan 29, 2010 | Computers & Internet
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
Hard disk drive not opening
Best is not to partition your Hard Drive to more then 4 partitions. If you are going to install more than 2 Operating Systems(OS) on your hard drive,be sure to set your partition to "active" for the intended OS before formating. If you set to more to 4 partition, most probably your OS will not be able to read the partitions and that are the reasons you are getting the errors.
Jul 30, 2010 | Microsoft Windows XP Professional SP2
I have been using my Maxtor external drive for about 3 months without any problems, but in the last week it has stopped working and I get the error message no external drive found or either either the...
Sorry, Maxtor prog on poota is currupted. Have you recently downloaded programmes? When updating, some progs have a nasty side-effct of hitting some other programmes, not all the time,just your important ones?
You will have to uninstall and reinstall Maxtor prog, Not sure there might be a repair facility, not sure but it worth a try before uninstalling all.
Nov 14, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Replaced hardrive with seagate 7200 500gb momentus
When you created a partition on the new hard drive, did you make the partition active?
A partition that has not been activated can be formatted and Windows installed, disk check etc. but will not boot up.
You can make the partition by booting up in DOS with either a floppy disk or a boot CD and run the DOS command "fdisk" and navigate to Set the partition active.
Aug 11, 2009 | HP 8710w Mobile Notebook
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
SimpleTech hard drive not found by my computer
This is because your bios is only configured to recognise up to 250Gb. what you need to do is download the latest bios updates for you mboard, install them on windows. then you shoud have no further problems with the HDD.
May 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
2nd partition disk drive D: is not accessible
Several brands now have the recovery software and backup of your computer on the D: partition.
You probably have XP (Vista doesn't try to stop you from viewing the contents of the drive). I would recommend using a 3rd party explorer clone to move the music files back to the C: and leave that partition alone. Also if you have not made your recovery discs yet do so before messing with the recovery partition.
On an HP or Compaq the recovery disc manager can be found under HP or under PC Help & Tools in the start menu.
Apr 02, 2008 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
386 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
