Question about Kenmore Dryers
Kenmore model# 66702692, making a thumping noise. I replaced drum belt..
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 15, 2010
What do we do to address thumping noise in Kenmore Elite HE4 Dryer?
It is probably one of the idler wheels it rotates on. Look for a flat spot and if you didn't replace the drum your self ask for your money back.
Dec 11, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 Series dryer's drum is making a thump
I would check all the screw's to make certain they are tight. That was my problem when mine was making noise. Look on the interior of the drum.
Jan 01, 2012 | Kenmore Dryers
I am looking for the drum size for a kenmore dryer model number 66702692
29 inch dryer... Drum PN 695587
If you need parts here is the link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11066702692/0582/0151200?searchedModel=66702692&blt=06
Belt is 5 ribs and 94 inches long. PN 660996
Substitution: PN 341241
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Kenmore Dryers
Dryer makes banging sound as drum rotates
The drum rollers are worn out and wobble when moving..it should be more of a thump/thump sound, unless really are almost gone...UNPLUG dryer and raise top...Since no model. i'm going with standard kenmore/whirlpool dryer type. The top has two screws by lint filter..Remove these and raise top...The front can be removed by removing two screws inside each front corner. The door switch must be disconnected at wiring..Remove front and set aside...The drum can be removed after the belt comes off...look down in right rear corner under drum..you will see the belt pulley and you want to see how it goes around pulley to help reinstall..remove belt, there will be tension and make sure you draw yourself a diagram of path of belt to ease install of belt....now once belt is removed, you can pull out drum...there are two drum rollers. They are bad if you roll them and they wobble and make noise. They should be almost quiet when you roll them if they are good..the belt roller can be bad and squeek...check this as well...replace parts and reinstall
Jan 31, 2011 | Dryers
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
Maytag dryer make very loud 'tumbling', thumping noise but the drum isn't turning. We just replaced the belt and all the wheels and pully's 'appear' to be in good shape. Help.
If you just replaced all that then maybe you dont have the drum put back in there correctly. alternately sometimes the fins on the inside of the drum are not tight and shift and make noise as the drum turns. You tighten those on the outside of the drum. Make sure you put the belt on right.The blower wheel may have worked itself loose. Make sure the belt is on right and the drum was not put back in backwards. Check that, if the other doesnt work. Last but not least I have seen on some Maytag brands the seam on the drum was not welded right and it popped opened/no longer seamed togerther...check that as well.
May 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Dryers Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
