Question about Fisher and Paykel GWL11 Top Load Washer
F & P Intuitive washer approx 10 yrs old Code 50 Whats the problem?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.The error code 50 is called HOT VALVE FAULTY.Does the error code appear in your LCD display when the machine is at the start of the cycle when it is starting to fill?The components that could be faulty are--water valves ----control module or wiring.This fault will also appear if the machine powers down while in the spin mode.To accurately diagnose the fault on your machine please reply back with additional information on all the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 14, 2010
  • 1 more comment
  • hgrally Oct 16, 2010
    Model iw709au
    where did u get GWL11 from?
    Because there is a little water left from when it stopped it checks water level - pump runs for a few seconds - retrys several times then the code comes up - pump is noisy as well - tryed to advance but does same
    Deperate
    Howard
  • luisa_sgro Oct 17, 2010
    Hi Howard just read your last posting.On this website I do not label your model of machine the owners of the website label the model of your machine not me.This is an American website so they labeled your machine with one of their models.Fortunately I am an Australian based service tech that knows your model of FISHER@PAYKEL well.In my 1st posting I mentioned that Error code 50 is called HOT VALVE FAULT.This error code is relevant to your model of machine which is an IW 709au.This means it is called an Intuitive Washer.As mentioned in my 1st posting the faults could be the hot water valve or the wiring to the hot valve or the control module.Try selecting just a cold water fill on med water level with traditional wash selection.You can do this by accessing the option mode on your control panel.I am trying my best to help rectify the fault on your machine and I do this for free so if you could reply back on how you got on with my suggestions that would be lovely.Looking forward to your reply.
  • hgrally Oct 17, 2010
    G'day
    Never used hot water in my life or the machines history has always used cold
Fisher and paykel intuitive washer what is a code 50 please
50. (00110010) Phase 2 to 5 - Hot Valve Fault
The Motor Controller has measured a voltage from the valve diagnostic circuit that indicates
that the hot valve is faulty. The most likely cause is that the valve harness has not been
connected correctly.
Primary Source - Wiring
Action - Check valve harnesses are correctly fastened to valves.
Secondary Source - Water Valves
Action - Check valve coils are not faulty ( open circuit ). If either of these valves are low
impedance it is likely that the Motor Control output has also failed, in which case replace Motor
Controller and valve(s).
NB. Phase 5 can give fault code 50 when Smartdrive powers off while spinning. In this case
there will be no fault.
Mar 18, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Hi i have a F&P intutive eco washing machine, approx 8yrs old & it seems to have trouble getting enough water & now after the first spin in shows fault code 136, i also have trouble with marks...
I have not had good experiences with this washer My personal opinion would be to purchase a good second hand washer from craigslist as the repairs on this unit will probably reach 300+ including parts. You can get good second hand washers for that or less.
May 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel intuitive Fault code 136
Sounds like a motor problem Check the motor harness,connectors and motor for discontinuity.This can be done by taking a resistance measurement between phases of the motor harness at the motor control mudule end.should be approx 32 ohms.You can also check at the motor,I have seen a few open circuit connections where the motor connections (spade clips) Push into the plastic motor housing,Hope this helps.
Sep 12, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Electronic display was flashing LE. Unable to open front load washer...no visible water. Tried to restart...unable. What is your best solution to open front and get washer working again? washer is...
Waht make? Model?
Sounds like an LG
You might want to unplug the unit for 10 min -then plug it back in and then power up , then press pause.
LE- could be a motor sensor, main board issue - wiring issue
Affordable Appliance repair
Orange County, CA.
Aug 22, 2009 | Washing Machines
We are renovating our kitchen & last week my husband moved thbe washer. It is taking in water but it then runs straight back out through the outlet hose....please can you help. It is a Hoover washer...
is the hose lower than the tub as this could lead to the water siphoning out due to gravity, the outlet hose standpipe should be at least as high as the top of the drum
Jul 15, 2008 | Washing Machines
Maytag neptune washer
yes, but 900 is a little high for my area. is it loud in spin now? the seal can be replaced for about 50-80 part labor is 1 to 3 hours. if you just smelled the smoke and it is not loud you are ok for a long time, reduce load size and it will probly be ok for some time
May 16, 2008 | Maytag Neptune Washer
Fisher and Paykel GWL11 Top Load Washer Logo
182 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
