Be sure to use a brand new sharp needle that is compatible with the thread and fabric (see link below). The type of needle may need a larger scarf/groove to shield the thread (ie, top stitch or embroidery) and pierce the fabric easier.
If your machine has the option for a straight-stitch (vs zig-zag) needle plate, you may want to try using that. The small needle hole will restrict the fabric from being pushed down into the bobbin area.
Do you just need new sewing machine needles? There are so many types it is dizzying. Go to a place like Hancocks, Joann's or Hobby Lobby. They will be able to help you. Nearly every type of fabric has a needle that will work the best with it. Good Luck! The needle most used is a 80/12. That is the standard needle.
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
Here's a tip
For the cover stitch, only use a size 90 needle. Depending on the type of knit, use a ball point or stretch needle. The 936 uses standard sewing machine needles, so you can switch needles with the type of fabric, just like with a sewing machine.
Hi. You use different size needles for different fabrics and fabric weights. Size 16 needles are used for heavy fabric, like canvas, duck, or blue jeans. Size 14 needles are still on the heavy/thick fabric size. Size 10 needles are for very light-weight fabrics and size 12 needles are for medium-weight fabrics. Also, you need to pay attention to the type of fabric--if sewing on knits, you need ballpoint needles. If sewing on woven fabrics, you need sharps or universals. Universals are supposed to be for knits, too....but ballpoint needles are SO much better!
Use the right size and type of needle for your fabric, don't sew over any pins (they can bend or even break the needle), and make sure you don't pull or push the fabric while you're sewing on it. Let the feed dogs do the work of moving the fabric--you just gently guide it.
Hope this helps!
