Question about Bosch 1646K Factory-Reconditioned 18V Cordless BLUECORE Reciprocating Saw Kit
I had the power go out when I was charging my battery and when it came back on the charger light was no longer working. I have tried leaving the battery on but it doesn't seem to be charging. Is there a fuse inside that may have blown or is the charger just toast?
2 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Bosch battery charger lights up as if charging.
its going to be pricy to fix the charger as its a switch moad type,,if you can get a new charger that a cheaper way out
Posted on Dec 02, 2010
Testimonial: "We thought that might be the case. Thanks for the affirmation. "
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Wont start up
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Tablet's battery lost power and won't recharge
Mar 07, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Battery will not hold a charge when on pluged
Feb 12, 2014 | Kocaso 10.1" Android 4.0 Tablet PC With...
DW911 charge light flashes when no there is no battery in radio
Sometimes when a battery is too low it takes a while for it to initialize in a charger and begin to charge. Clean the battery contacts with a pencil eraser and put it back on the charger. Leave it on the charger despite the blinking light. Leave it on the charger for several hours and see if the flash stops and it becomes a constant light indicating normal charging. If this does not work, you may have a short in the battery or in the charger itself. Try another known good battery in the charger and see if you have the same problem. If so the charger has an issue.
Best regards.
May 22, 2013 | Radio Communications
My game only works when on charge. When the charger is pulled out the games turns off. When on the charger base there is a constant blinking green light.
  • That blinking green light means the rechargeable batteries are no longer holding a charge which is also why the unit shuts down when the power feed is removed. You just need a new set or rechargeable batteries is all. 4 AA (or LR6 depending where you are)
  • Please note that when the charger rapidly blinks green, in addition to the batteries that are failing, they can overheat and leak. Please, cease to use those batteries and take them to a recycle place before they begin to leak from trying to charge when they are not safe to charge anymore.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Oct 05, 2011 | LeapFrog LeapSter L-Max Console
No problem, just ?
No issue. The charger is adapted to the battery. You can leave the battery over night in the charger without problem. The fact that the light goes off means that the charger surveys the voltage and switches off when the battery is charged.
If you leave it longer and the battery looses charge, it will be recharged automatically.
Cheers
Critter1965
Dec 27, 2008 | Olympus FE-340 Digital Camera
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Battery won't charge
clean the contacts of the battrey and the charger.if that does not work replace the charger or the battery.goodluck.
Apr 03, 2007 | kawasaki PVS-10921 Portable DVD Player
Bosch 1646K Factory-Reconditioned 18V Cordless BLUECORE Reciprocating Saw Kit Logo
49 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
