Question about Royal MC50MX Shredder
Shredder just stopped while in use. Is there a reset button?
    Genius:
  • 1,218 Answers
No...if it overheated and shut off..then afer about 20~30 mins it should be cooled back down if its going to work...if the Pcb inside has blown you can contact Royal at 1-800-524-0799 for parts assistance.
Posted on Oct 24, 2010
I have power in the shredder but the shredding mechanism will not work..I cleaned it as well and looked at the shredder itself. they move when I push on the gear manually. tHE FUSE LOOKS FINE.
Take a look at the motor for a reset button. Some times they overheat, and a reset is needed. Not all motors have reset buttons, but it is worth a look.
Also, test the fuse to ensure it works. Sometime fuses will fail electrically, while appearing normal visually.
Make sure the unit is unplugged before poking around.
Apr 20, 2015 | Shredder Office Equipment & Supplies
Do you have info on paper shredders that just stop
shredders have a small tag next to the cutter wheels that move when you insert paper to shred. This tag is easily jammed or damaged during operation. It is normally about the middle and will be positioned between two blades. If this is not moving when paper is inserted it will not switch the machine on. It is the same switch that wwhen jammed by paper will not switch off the machine after paper has been shredded.
Nov 08, 2014 | Office Equipment & Supplies
No power to shredder, no reset button, reverse will not solve
The motor may have overheated and failed, especially if the shredder was operated at its rated capacity or operated continuously for long periods of time. The specs for these devices tend to be exaggerated.
Apr 22, 2014 | Ativa Hd1600 16-sheet Cross-cut Shredder
Is there a reset button on the Royal VF700 Crosscut Paper Shredder?
No reset button just unplug it or safely lift the top out of the trash can then the Disable/Safety Switch will make it stop (located on the right side towards the back of unit
Jan 13, 2011 | Royal VF700 Cross-Cut Shredder
My paper shredder wont turn off
Shredders have sensors that tell it to turn on. Usually the there is a spring loaded button/sensor in the middle of the slot that you feed the paper in. Once the sensor button is pushed down, it thinks a piece of paper is being fed in and begins to turn the blades.
If your shredder won't stop running, I think the sensor button is stuck in the down position.
1) try pushing the reverse button for a while to see if it clears the problem.
2) if not, then unplug the shredder. Find the button/sensor near the middle of the shredder slot and with a tweezer, try removing any clogged scraps of paper near the sensor button to get it to pop up fully.
3) I've never seen a shredder with more than one sensor in the middle but if yours has more, make sure they are all in the popped up position when there is no paper in the shredder.
4) Plug the shredder back into the AC outlet and try it again. Good luck
Aug 08, 2010 | Office Equipment & Supplies
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
Green light wont go on after clogging. is there a reset button?
Last time this happened to me I ended up taking the shredder to bit to clean out all the paper. When I re-assembled it never worked again! I'd get it serviced or just replace! Shredders tend not to come with an reset (or useful!) options!
Dec 13, 2009 | Office Depot Ativa DQ60M Shredder
It stopped working after a big shred. I suspect an overheat. How do I reset it?
it's overheated, after you turn on the shredder, is it working?
if not, that means your shredder's motor is death.
need to buy a new shredder.
May 06, 2009 | Office Equipment & Supplies
Gbc shredmaster 4220S just stopped working
Check swich door , if door is open the machie stopped for securyti of the operator . the swich is closed whith the door is closed , good luck
Oct 31, 2008 | Quartet gbc 4220S Shredder
My shredder stopped working
I hear about this all the time where I work, unfortunately the motor got overheated and is dead. If the shredder is still under warranty you may want to contact Fellowes and see if there is anything they can do.
Aug 26, 2007 | Office Equipment & Supplies
Royal MC50MX Shredder Logo
208 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
