Question about RCA F38310 38" TV
The tv will not let me channel search keeps telling me to unlock threw service menu. tv will not work on antenna a or b and when im using the dvd threw one of the imports after five to ten minutes the tv goes into satalite search
    Top Expert:
  • RCA Master
  • 74,384 Answers
Your tv is tuning locked. Go to menu and get the tuning lock function by pressing PR+,PR- keys. Reach to the tuning menu by the help of Vol+, Vol- keys. Select the tuning lock fumction, and turn it to 'off' .
Posted on Oct 15, 2010
Channel setup
It sounds like the tv isn't finding any channels and that is why it keeps trying to repeat the search. In the cable/antenna input selection in tone setup menu, make sure you have it set up for the correct signal type. If this doesn't work, you may have a bad TV and should take it back to the store before the warranty is up.
Nov 29, 2013 | Sansui 19 in. LCD TV
I don't want to use the antenna on my Sanyo Ds20930
You have to enter its service mode to rectify this problem. Just contact any expereinced tech, as this is a very risky and skilled work. The tech know, what to do.
May 22, 2012 | Sanyo DS20930 20" TV
Dont know how to channel search with remote
Do these steps using the remote: Power TV on. Press Input button and < or > to be sure you're looking at TV and not HDMI1 or something. Press Menu button and > to the 4th (I think) menu, where top two items are: Tuner Mode and Auto Scan. You ought to be able to start an auto scan with those. It takes a while, maybe ten minutes to finish, so be patient.
May 08, 2009 | Hannspree XV37 HDTV 37 in. LCD TV
Technika 15.4'' tv/dvd can't find antenna that is plugged in
When almost all TV stations went digital, analog TV signals received via an antenna all but disappeared in the United States. So you will not be able to get much, if anything at all without a digital TV connected to a cable system or a satellite system. Welcome to the new economy! You want it? You will PAY for it! Radio (first FM, then AM) will most likely be the next casualty of the new economy!
Apr 19, 2017 | Televison & Video
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Televison & Video
Video channel disappeared
i just got mine to work i had the same problem, i bought a universal remote, make sure your dvd player or whatever his hooked in, and hit the input button on the remote, it worked for me. I couldnt get anywhere by looking through menu, but i just hit the input button and it magically appeard :)
Feb 23, 2008 | Symphonic ST420FF 20" TV
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
RCA F38310 38" TV Logo
146 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
