Question about Maytag MMV5156AAS Microwave Oven
Microwave Handle Replacement mmv5156aas
I am trying to replace my microwave handle and am having trouble. I have removed the plastic ring around the first 2 screws, but I don't know how to remove the door to bet to the 2nd two screws. Any suggestions?
Thanks, Heidi
  • susanbeeray Apr 17, 2009
    I have removed the door frame and the 2 screws that were attached to the handle. I am now supposed to remove the spring latch but I don't know what that is? I can guess it is the thing that slides up and down to latch the door but it isn't obvious how to remove it? sbee
  • Maytag Master
  • 9,098 Answers
Normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
Over the range microwave handle melted
To replace the door handle, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 04, 2009 | Maytag MMV5156AAS Microwave Oven
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
I hope this helps you.
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
How to fix a broken handle?
NOTE: If your microwave is the same model you have this listed under, I could only find one website that offers the handle as a separate replacement without purchasing the entire door (the entire door cost over $200!). The handle lists for about $51 at repairclinic.com. You can search around, but I have already tried the following sites:
repairclinic.com
Aug 12, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
How to change the handle
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
May 14, 2009 | Kenmore 62702 Microwave Oven
Microwave broken door handle.
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Apr 23, 2009 | Microwave Ovens
Broken handle
Almost all microwave ovens manufacturers locate the handle mounting screws behind the inner black plastic frame known as the 'choke'. If done very carefully, the choke can be removed with a putty knife without breaking it. My suggestion would be to order a handle and a choke. HOWEVER ordering a complete door will be less aggravation and not a lot more money. The handle and choke will cost around $120.00 whereas a complete door goes for around $130.00. Check out www.searspartsdirect.com for more detail.
Feb 03, 2009 | Frigidaire FMV156DC Microwave Oven
Another broken handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door handle replacement
Solution for GE Spacemaker Ovens (my model is JVM1650BH05)
1- Remove door by lifting it out of hinges. You will need to remove grille first (2 set screws).
2- Carefully pry off the plastic inside door trim. Use a fine knife or putty knife. There are 10 tabs holding the trim from behind. It's OK if you break a tab! Try to pull out as straight as possible.
3- Once the trim is off, remove the 2 visible screws that hold the door handle. NOTE: There are 2 invisible screws so you are not done yet!
4- You now need to remove the metal ring that holds the latches. To do that, grab the metal ring and using your other hand, release each plastic tab one by one (same tabs as above).
5- Once the metal ring is loose, you will see 2 screws. Remove them if they are still there.
6- Position your new handle and attach using the first 2 screws.
7- Reposition the metal ring by re-snapping it in place. Install the other 2 screws.
8- Replace the plastic trim by snapping it back in place
9- Reinstall door and grille. Tell wife or hubby that you are a genius!
Bonus: use metal washers when screwing down the 2 first screws.
Mar 10, 2008 | Microwave Ovens
Replacing door handle
The choke cover (or door gasket on your brand) will come out similar to the diagram shown below.
Then the hidden screws should be visible.
Also, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 20, 2007 | Maytag MMV5156AAS Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
162 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
