Question about Whirlpool LGB6300 Gas Dryer
My dryer will heat and tumble, however, it is difficult to get it to start and it won't stay running. What can I do about that?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 15, 2010
  • 76 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
PSUinNC The first thing you have to do is to check in what position is the temperature switch . If the temperature switch is in the "air fluff" position, then the heater will stay "off". If this is not an issue, reset the circuit breaker. The motor needs only 120V to run, but the heater needs 240V and if one of legs is missing, the dryer would not heat. If it did not solve the problem, you have to perform full diagnosis. You will need some simple hand tools and a meter to check a continuity. If you are fillng you can handle it, let me know and I'll give you the step by step instructions. Gendos...post back
Posted on Feb 26, 2007
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
  • 67 Answers
SOURCE: dryer does not tumble, but heats up
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
futureloginn
  • 734 Answers
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
SOURCE: Candy Nova CDC 266 tumble
hi ya this is the thermostat at the back of machine external,take the fan housing of it is nomaly the top one .beware change like for like do not exceed the temp rating of the stat.
hope you solve it
andy bird www.shropdive.co.uk
Posted on Dec 31, 2008
My Kenmore Elite 110.62932100 won't tumble or heat up.
try the homes 240volt circuit breaker it may not show its tripped but one of the 2 phases can trip out, (just reset the breaker) and if this happens either the dryer drum motor will turn or the timer will run, but not both as these 2 components each use 1 of the 2 phases 120 volts to run,but the heating element needs both 120volt phases for 240volts for the heating element to heat,this is what your issue sounds like to me,hope this helps
Dec 09, 2012 | Dryers
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Why won't my dryer heat up?
There are several reasons for no heating on a Tumble Dryer. The heating element could be faulty ( open circuit.) There are several thermal cut outs which can also go open circuit The only way to check is with a Multi Meter by a qualified service engineer.
May 26, 2012 | Kenmore Dryers
Won't tumble. Drum won't roll. How do we open it
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Dryer not tumbling heat but no tumble
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Apr 19, 2010 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
My nepture dryer wringles the clothes very badly
Most common problems with wrinkles is too much clothing is in the dryer causing and allowing to tumble freely. 2nd, the dryer is not putting out enough heat and cause the clothes to stay damp and stay winkles. 3rd the exhaust fan may be not working properly. you might able to solve the problems by trying to reduce the amount of load, allow it to tumble freely and I don't know if your dryer are putting out enough heat. the cause of low heat can be the heating element is going out. hope that help some.
Aug 09, 2009 | Maytag Dryers
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LGB6300 Gas Dryer Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
