Question about Car Audio & Video
I need a wiring diagram for a 1994 Holden Barina stereo please
ABKS
  • 39 Answers
SOURCE: I HAVE LOST CODE FOR
Call your local dealership, give them your VIN number and they can give you the code.
Posted on Oct 09, 2008
  • 109 Answers
SOURCE: 2004 Chevy Tahoe stereo wiring diagram
BLACK-ground
RED-accessorie
YELLOW-power 12v
PURPLE-left rear
GREEN-right rear
WHITE-left front
GREY-right front
BLUE-REMOTE
and the other blue one is for remote antenna..
Posted on Dec 04, 2008
MrScary66613
  • 1990 Answers
SOURCE: changing a fuel pump on a 1991 holden barina
The Fuel Pump is Inside the Fuel Tank. You will need to Trop the Fuel tank for this. Not an Easy Job by any Means.
Posted on Jan 22, 2009
emissionwiz
  • 75197 Answers
SOURCE: Need a stereo wiring diagram for 1994 Ford Tempo.
1994 Ford Tempo Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Posted on Mar 25, 2009
  • 44 Answers
SOURCE: Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
Posted on Jun 28, 2009
Holden barina manual
If all else fails, test with a test light or a multimeter set to VDC.
Aug 10, 2014 | Holden Barina Cars & Trucks
I need a diagram for the fuse box located near the battery of a holden barina xc 2001 as I need to find which fan relay that keeps coming up on the computer. I have one diagram of the one near the front of...
GMC xc barina fuse box location Questions & Answers - Fixya
www.fixya.com/tags/xc_barina_fuse_box_location/browse/gmc
Locked stereo in 1995 Holden Barina My battery went flat in my barina and now the ... Just changed the battery in a 2001 Holden Barina now there is no power just ... fuses should be in the box under the hood, there will be a diagram showing ... a 1984 gmc jimmy s15 fuse box located? the fuse box should be located near or ...
2002 Holden Barina Comments (r97719), Page 4
www.carsurvey.org > Holden > Barina > 2002 > Review
Apr 19, 2013 - 2002 Holden Barina from Australia and New Zealand - Comments ... The relay is in a box with a plastic cover on the left side (passenger) beside ... Hi, your Combo problem is the MAF sensor located near the air intake ... Hi I was hoping youfound the problem to your car, as my daughter's 2001 XC Barina is ...
[PDF]holden barina fuse box diagram - Donnie Slocum
www.donnieslocum.com/file/h/holden-barina-fuse-box-diagram.pdf
Dec 04, 2013 | 1996 Ford Probe
1994 holden barina
you need to take the top off to get to the head bolts inside. top is cam cover. then it is the head.
Oct 13, 2013 | Cars & Trucks
1992 barina wiring diagram
hey go to nearest autozone. alot of time they can print you out a diagram with specs you need at no cost. i do it alot
Aug 12, 2012 | 1992 Holden Barina
1995 holden barina wiring diagram
The flashing unit ...Where do I find it ? 1995 Holden Barina
Jun 25, 2012 | Cars & Trucks
Holden barina 2000 model i need to know what colour the remote booster is in the wiring loom ?
In late 1998 there was an update featuring multipoint fuel injection across the range and suspension upgrades to improve ride and handling. These models can be identified by their half body coloured bumpers and 3 bar grille. In 2001, Holden issued a voluntary recall of all Barina SB models, built between 1994 and 2001
Nov 22, 2010 | Car Audio & Video
Holden barina 1994 manual gearbox linkage problem
had the same sorta problem with my one, i replaced the las part of the linkages thats connecte to the gearbox, that helped with it. also check to see if the blots holding ur gear stick in place are tight
Sep 01, 2009 | 1994 Honda Civic
Wire colour coding for radio Holden Nova LF
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Aug 30, 2009 | 1994 Toyota Corolla
Removal ov stereo in 2004 holden barina sxi
hi there i just removed my stereo out of my 05 barina today the best way to do it is get yourself four screwdrivers that fit in the holes after you have removed the alan key screws,
then what you do is put all four screwdrivers in the holes and squeeze the screwdrivers for example press the top one's down and the bottom one's up and pull and jiggle and you should get it out...
I am actually looking to replace my standard one if you are interested in selling it please email me jai.siddiqui@gmail.com
thanks
Jai
Dec 22, 2008 | Car Audio & Video
Car Audio & Video Logo
389 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
