Question about Whirlpool Dryers
My dryer wont even turn on - Whirlpool Dryers
  • Whirlpool Master
  • 3,740 Answers
Hi and wlecome to FixYa I am Kelly.
Open the door and turn the drum by hand. Your checking to see if the belt is still around the drum and not broken. If it turns with little resistance the belt has broken and the belt safety switch will prevent the dryer from working.
Also listen for a door switch click just as the door opens and near the closed position. No click = bad door switch.
A bad start button relay wil also cause this.
Addiitionally if the dryer is full of lint and the one time fail thermal fuse / thermistor has opened from excessive heat due to lack of airflow it will not start.
Check around the lint filter, in the dryer exhaust duct and all the way through to the outside wall for lint obstructions.
Lastly a broken blower wheel hub will cause lack of air-flow and result in the thermal fuse failure.
If you want your model specific data, please repsond with your model number.
Thanks for choosing FixYa.
Kelly
Posted on Oct 14, 2010
Dryer wont start wont even turn on, it doesn't seem to be getting power
bad door latch, or door switch likely. worst case main control board.
Oct 04, 2013 | Dryers
Dryer wont turn on
Lots of things it could be. I'd try the shut-off switch first.
There is a switch that is supposed to turn off the dryer when you open the door.
That switch is often made of plastic, and can break or even fall out inside the machine.
After that, I'd check the start switch to see if it failed.
Be blessed.
Feb 17, 2013 | Crosley CDE6000 Electric Dryer
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Kenmore Dryers
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
i ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Jan 02, 2011 | Kenmore Dryers
Power is on and seem to be normal, but dryer not turn
belt maybe even the door switch:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 30, 2010 | Samsung 7.3 Cu. Ft. Electric Dryer
My kenmore gas dryer ,model number 87673800, wont start anymore. It worked fine and then during use it turned off and wont come back on at all. Even the light is out inside. Any help would be greatly...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 21, 2010 | Kenmore Dryers
Light comes on wont spin wsr-maytag mod m6d5600tqo ser mw2607338 type bwsr-nat-1206006-fm22 light wont turn off even with door closed dryer is not old new in 2008
Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
J. Lewis
Dec 21, 2009 | Maytag Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Oct 15, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
