Question about Dewalt DEWD28110 Heavy Duty 4 12" (115mm) Small Angle Grinder
I have a D28110 grinder and it started making a loud noise (not the regular noise) and got very hot at the front where the gears are. I removed the gears cover and tried to get the shaft out of the casing but I do not know how to get it out. I tried un-screwing counter clokwise but didn't work, I tried tapping it out but it does not move. How is this part dismantled? Please.
  • 41 Answers
You have to pull the brushes back there should be screw caps on the back (cord end) remove them and take out the brushes if the gears are ok and there is grease in ther then it will be the brushes or the bushing on the back
good luck
Posted on Oct 24, 2010
While using my dewalt 7amp small angle grinder (using it on and off about an hour grinding hard walnut wood) I heard a pop inside the unit so I turned it off, then a few seconds later turned it on again it...
burnt out the motor
the fix is a new unit
when grinding or sanding you use light pressure and let the disc do the work
change or unclog the pad or disc on a regular basis
for fast rip down use very course then finish with a fine pad
Jul 31, 2017 | Dewalt 65091601 Brush Set D28110 D28112...
I have a 1999 Suburban with the 5.7. It has the 4 speed transfer case (4hi, pert time 4W, 2hi, 4lo). It started making a very loud noise that sounds like a bench grinder. It won't go in reverse,...
Been there done that, I have same problem ,its the transmission, Why if it was the transfer case,look at the design it couple the drive shaft ,there a gear and chain attatched by a gear drives the front drive differential,You have a transmission failure
Nov 10, 2012 | 1999 GMC Suburban
I have a D28110 angle grinder and I want to use a 1/8"cutting disc with it. Do I need a different guard than what it came with?
haven't heard of a different guard for the cutting disc you want to use. Most people remove the guard when using them
Sep 15, 2011 | Dewalt D28110 Heavyduty 412" Small Angle...
I have a Breville BES860XL and the grinder is not working. If i overide the interlock, It will spin, but does not have enough power to grind beans
It seems there's a fault in the grinder gearing in this particular model.There's no solution but to take it to Breville repair...
I have the same problem and so does a friend of mine. The grinder will spin without beans in the hopper but as soon as beans are introduced the grinder makes a loud noise. Like the gears are slipping and there's not enough power to grind.
Jun 10, 2011 | Breville BES860XL
My grinder d28110 dewalt stop working. My friend told me that it may be the problem with brush. I opened the machine but I do not now where is the brush and how to replace it. Please help, Bozena
Most times , unless the unit has been used a big bunch, it's not the brushes it's the comentator that the brushes run on . spin it in the clockwise position while holding some crocus cloth to clean it. Remember to clean each groove as a piece of metal could short two copper pads and burn a wire and cause a dead spot. This can make act like a bad switch.
Nov 15, 2010 | Dewalt 65091601 Brush Set D28110 D28112...
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
Machine makes a loud wheezing noise just before
Mite have a broken gear in the fusing section (Hot Part) unplug machine and open **** shell and look to the left (if standing in front of machine) the left side rear is the fusing drive section check all gears also remove image unit and check gears
May 02, 2009 | Minolta Office Equipment & Supplies
Dishwasher making loud noise
Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
Jan 10, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Dewalt DEWD28110 Heavy  Duty 4  12" (115mm) Small Angle Grinder Logo
132 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
