NORTON 360 PROGRAM NOT COMING ON. WHEN SHORTCUT ICON CLICKED IT DOES NOT START. IT ALSO HAS DISAPPEARED FROM THE MENU BAR AT BOTTOM OF COMPUTER.
  • 137 Answers
Check your Startup list using the msconfig tool. Also may want to check if the service is running using services.msc
Posted on Jun 02, 2008
Why is my norton icon no longer on my desktop
Assuming your version of the program is still valid, go to the start menu,select all programs, find the right one, RIGHT click on it, select "create shortcut" and drag it onto the desktop
Aug 29, 2014 | Symantec Norton 360 Full Version for PC...
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
My printer icon has disappeared from my desk top.
Is that a shortcut icon?
You can create another shortcut,
1.) Go to Start Menu\All Programs\
2.) Right Click on the application ICON.
3.) Navigate to Send To\Desktop(Create Shortcut)
Mar 18, 2011 | HP Officejet 5610 All-In-One InkJet...
I cannot see vedios
I hope the issue is not related to Norton.
To confirm, please disable the Norton program on your computer and check if you are able to watch videos.
To disable the Norton program, right click on the Norton icon which is on your task bar's bottom right side.
Then, click on turn on silent mode, disable smart firewall, disable antivirus auto protect. It will disable the Norton product for a few minutes. To enable them, please open the Norton program and click on "fix now".
Regards,
Muhaim
Dec 30, 2010 | Symantec Norton 360 Full Version for PC...
I want to have YAHOO MAIL logo on desktop
Hello there!
Any of these ways will put a Yahoo! Mail shortcut icon on your desktop. If you want another Yahoo! shortcut instead of Yahoo! Mail, just substitute that Yahoo! page for Yahoo! Mail in the instructions.
To put a Yahoo! Mail shortcut icon on your desktop, go to Yahoo! Mail page http://www.mail.yahoo.com/ , at the top of your screen click File, a menu drops down, put your mouse cursor on Send, a menu pops up, click Shortcut to Desktop.
Another way: Go to Yahoo! Mail page, right click on a blank space, a menu pops up, click Create Shortcut, a pop up asks "Do you want to put a shortcut to this website on your desktop", click Yes.
Another way: If it is listed in All Programs: Click Start > All Programs > right click on Yahoo! Mail > point to Send To and on the menu that pops up click Desktop ( create shortcut ).
Another way: Right click on desktop > point to New and on the menu that pops up click Shortcut > in the box that opens type http://www.mail.yahoo.com/ > click Next and in the next box that opens type Yahoo! Mail and click Finish.
Another way: Go to Yahoo! Mail Page > left click and hold on the blue bar at the top of your browser window and pull down far enough to expose the desktop, or drag one side in or the bottom up far enough to expose the desktop (if it won't move, click the box beside the X at the top right corner of the screen to Restore Down) > left click and hold on the icon on the left of the address on the address bar and drag it to the desktop and release it, then you can minimize the window and left click on the icon and hold and drag it to where you want it on your desktop.
Dec 03, 2010 | Yahoo Mail
Do not have a norton 360 icon on desktop only have norton internet secuirty or symantec live update which will not do anything when clicked on ( norton 360 not working on this computer )
Did you purchase the 360 program if so sometimes after you install it wont automatically place an icon on the desktop if you fail to check the little box during installation. If you have purchased it you can locate it in the start menu. Locate the folder and right click to pin a shortcut to the desktop.
Mar 23, 2010 | HP Pavilion dv6000z Notebook
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
The norton icon is gone from my computer. it was there yesterday.
Hi mph810
You can put the icon back as follows
Goto the
Starts -> All Programs
Move up or down, to locate the Nortons program.
Once you find it, bring the mouse on it and Right ClicK to get a popup menu Depending on which Windows O/S, you have, you will see one of these Create a Shortcut OR if it is not there you will find Send to ->
Click on this to open ; Select the Desktop.
This will create a shortcut and place on your desktop.
Hope this will help you.
if it is helpful, please give a rating.
luciana44
Nov 28, 2009 | Gateway Computers & Internet
My yahoo messager will not load when u click on it from the starst menu. i uninstalled the messager and downloaded the latest version and installed it. now when i click on the start menu for messager or...
Try this:
Using explorer go to the c:\Program Files\Yahoo Messenger (or whatever you named it) directory + right click on the program icon (EXE file) + send to + Desktop.
Than delete the old icon as it doesn't work anymore.
Mar 02, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
David Payne
David Payne
