Prablon may loptop pxe-mof exiting broadcom pxe rom .broadcom undi pxe-2.1 v14.0.8
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
I think you hard drives failed. When the hard drive fails, the boot tries to find another way to boot up, so if the boot sequence lan is enabled, it will try to boot from the lan port (in your case broadcom pxe), when it can't boot from here either, it exits (exiting broadcom pxe). Replace your hard drive and re-install windows.
Posted on Oct 14, 2010
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Broadcom UNDI PXE-2.1 v12.20 copyright(c) 200 - 2009 broadcom corporation copyright(c) 1997- 2000 intel corporation all rights reserved client MAC ADDR: 88 AE 1D 6F 5A 3A GUID: 478ADE06 B852 67B5 10E7...
From the description it is the hard drive, remove hardware and reseat back into position, sometimes this will restart the hard drive, if no change chances are you will need it replaced, but I would suggest getting it tested first.
May 26, 2012 | Acer Aspire Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
No bootable CD in ATAPI CD-ROM Intel UNDI, PXE-2.0 (BUILT 082) copyrighr (c) 1997-2000 Intel coperation For realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v.2 13 (0203326) PXE-EGI: media...
try downloading from here
http://pci-ven.com/driverdetector/realtek/rtl8139realtek/realtek-rtl8139-x-8130-810x-pci-fast-ethernet-controller-v2-17-051202-.html
good luck
Nov 08, 2010 | Acer Aspire 5100 Notebook
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Mar 31, 2010 | Lenovo 3000 G530 Notebook
Not Starting
This is the PXE boot for the factory, or a tech to shoot windows into it. As the machine starts, press the key that will get you into the BIOS to make sure the hard drive is the first boot device. If the computer then comes up with "No Operating System Found" you will need to get it reloaded. You get a windows cd, go back into the BIOS, set the cd drive as first, then save and restart. Press any key when prompted, and follow instructions.
Jun 30, 2009 | Lenovo 3000 N500 Notebook
My acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Jun 07, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
344 people viewed this question
David Payne
David Payne
