Question about KitchenAid KGRC707 Stainless Steel Gas Kitchen Range
I recently install a new control panel & display board now f1 e3 displays in clock . Any ideas of reason why ?
  • billurban685 Oct 15, 2010
    The way we solved this problem was by entering the end of service procedure waiting at least 4 sec between each step than pulling plug
    President:
  • 1,430 Answers
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Posted on Oct 14, 2010
  • billurban685 Oct 14, 2010
    How do you determine what jumper or what terminals should be jumped .
  • marka19
    marka19 Oct 15, 2010
    It usually comes with the part. If not try the tech sheet. The tech sheet should be located somewhere on your stove.
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
E3 F1 displayed and will not go away after pressing cancel. Don't know what is wrong.
Please check the full model number of the range.
The F1 E3 error is one found on ranges made by Whirlpool. It indicates that the jumpers in the wiring harness have been set to a different cavity (oven size) then the one previously stored by the range. Check that jumpers are correctly configured to match the actual oven size.
If you haven't had any repair work done on the range recently, you should contact a service person.
The 79012 model number gives me full model numbers similar to 79079012100. Sears Parts Direct does not have parts for the range. However, I suspect the control board has failed.
I hope this helps.
Jul 08, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
E3 -F1- this message just started showing up on the display of my Kenmore Ultra Bake Oven Md#66575842003
Hello there and thank you for choosing fixya
The E3-F1 ERROR CODE is a fault code that tells the consumer that the ovens main controle panel has a problem
This could simply be a wire that has came loose but a lot of the time the controle panel has failed and will need to be replaced
Here is what you can do
First disconnect the power Totally and slide the oven out and if you can remove the back of the unit and check to see if there are any wires that are loose or really greasy if so clean them and replace them also remove the panel at the top to expose the control board and do the same thing as in the previous step.
If you can find the wire harness look for the place where it attaches to the board and disconnect it then wait 30 seconds and reattach it.
after this has been completed leave the oven unplugged for at least 45 min total to allow for the internal reset feature to attempt to reset the memory feature on the oven then replace the back of the oven and any other parts that may have been removed
plug in the oven and press the cancel button if the error is still showing then yes the board is fried and a new one will have to be installed ok?
Hope this is very helpful for you
Best regards mike
May 03, 2011 | Kenmore Ovens
What does E1 F1 mean? can't set clock or use oven
Hello & Welcome to FixYa
Error code F1-E1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Apr 12, 2011 | Whirlpool Accubake RF362LXTT Electric...
After 10 minute power failure the Code E1 F1 keeps appearing on display and will not allow me to clear or reset
the error code means that there has been a eprom error. Follow the directions below, if this fails to clear the errror code you will need to replace the control board.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
If you have any further questins please feel free to ask.
Nov 17, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
What does E1 - F1- mean on display?
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2010 | Whirlpool GR478LXP Electric Kitchen Range
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Error Code F1:E3
reprogram the control board as following:press buttons on range
power off wait 5 sec
power on wait 5 sec
convection broil
clean
backed goods
stop time
190
timer set
start button 12 times(it will go through all the settings)
Mar 17, 2008 | KitchenAid KESC307 Electric Kitchen Range
CONTROL PANEL
you are having a problem with your electronic control panel.to solve this problem you have to replace electronic control board and touchpad assembly.
Jun 17, 2007 | Kenmore 75002 / 75004 Gas Kitchen Range
KitchenAid KGRC707 Stainless Steel Gas Kitchen Range Logo
212 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
