Question about Maytag Neptune Washer
I have an FAV6800AWW Neptune washer, and the water would not stop going into it. I hope it is a water control valve, but I am not sure. I am not getting any error codes, but the washer will not run because the water level is probably too high. Should I change the valve assembly and hope for the best?
  • 132 Answers
You might want to ccheck your switch cause a washer detects its changes by weight not level like a capasity sensor ?.
Posted on Oct 14, 2010
  • richhuhn Oct 14, 2010
    Sorry I do not know, but which switch? I thought that if the water did not stop going in, the water supply cut-off valve must have failed? Thanks.
Neptune HE TL FAV6800aww
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.
Jul 03, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Have Neptune FAV6800AWW top load, washes when it gets to the rinse cycle it stops with water in. If we remove the clothes and wait a while we can get it to complete. The code we are getting is DR which...
Are you sure the error code is DR? Could it be DC an unbalance error code. Google ""16022808.pdf"" to find. Is the washer banging around in Spin Cycle? If so this is a Clutch Pulley issue.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
DR is not a listed error code in the FAV6800A/FAV9800A Service Manual.
Aug 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have no water to fabric softener dispenser I
Google Neptune TL Washer FAV6800AWW
You can get the FAV6800A/FAV9800A Service Manual and get into Service mode and turn on the Cold Water Inlet valve and the Fabric Softer dispenser valve and see if water flows to the Softer reservoir. You may need to replace the dispenser valve.
Pic below. Post in the other forum it's easier to work the issue at a true DIY forum.
Mar 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washer starts and after about 5 minutes gives out... i get an nf code... anyone dealt with this
That's a No Fill error code. Is there any water flowing into your machine?
May be a block in the in the Water Inlet Valve. If it was false I feel you would have to break out the mop for flood/over fill condition. Did you try to fill with a mix like Warm/Warm selction?
If you want to troubleshoot further go to a real DIY forum.
Google this Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It
Feb 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Softener or Bleach will not dispense. Any idea how to fix this problem? I have Neptune TL washer FAV6800AWW.
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softner dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open or loss of 120VAC from the Control Board to the valve. Do the same for the Bleach Dispenser Valve.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach dispenser valve.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or find best price. Before I would order any parts you need to isolate the fail point, this could be a Control Board issue or machine wiring harness issue.
Did both reservoirs stop flushing contents at the same time or different fail dates?
Rich
Apr 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
At the end of cycle washer will not stop filling and overflows. maytag neptune fav6800aww
There is a diaphram switch located in the machine at the bottom right in the rear. When you remove the front panel it will be all the way back on the right. It senses the water level. It has three levels it detects. I had a problem with mine filling too much. That should take care of your problem.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
